c.1980 Nauset Appraisal
Vtwhaler
Postby Vtwhaler » Sat Apr 22, 2017 1:40 pm
A friend of a friend has an early 1980's Nauset hull with no motor, and the interior needs replacing. Basically I'm buying it for the hull. Can anyone give me an idea what this is worth? Thank you
Re: c.1980 Nauset Appraisal
Postby jimh » Sat Apr 22, 2017 2:00 pm
The last NAUSET was made in 1973. Any hull from c.1980 would be a "17" hull, with better engine splash well, the bow "smirk," and other improvements.
If the hull is really a c.1980 and is sound, has no damage, is not filled with extraneous holes, has original gelcoat in excellent condition, has no bottom paint, and has clear HIN and stencil number, it is worth a lot more than a pre-1973 hull that is waterlogged, damaged, filled-will holes, re-painted, bottom-painted, without stencil number and HIN. In other words, the value is all about the hull's true age and condition. My estimate: $100 to $2000.
For more advice on buying a classic Boston Whaler boat, see
BUYING CLASSIC BOSTON WHALERS
http://continuouswave.com/whaler/reference/buying.html
