2003 170 Montauk: Replacement part for sump cover plastic door catch
Riverdance
Postby Riverdance » Tue Apr 17, 2018 9:17 pm
Where can a replacement for the black plastic hardware on a 2003 Boston Whaler 170 MONTAUK boat that is mounted on the inside of the sump cover which keeps the cover in place on the deck be purchased? Thanks Tim
Ridge Runner
Re: 2003 170 Montauk Replacement part for sump cover plastic door catch
Postby Ridge Runner » Wed Apr 18, 2018 5:36 am
Tim - unfortunately that part does not carry its own part number. As you can see the factory parts listing and diagram show it as part of the cover assembly.
The cover is line number 15:
You should call Boston Whaler Customer Service at 1-877-294-5645 and ask for the manufacture of the part number 1689752 cover's door catch.
Member since 2005
Re: 2003 170 Montauk: Replacement part for sump cover plastic door catch
Postby jimh » Wed Apr 18, 2018 11:17 am
RIDGE--great answer; thanks for looking up the drawings.
I suspect that a suitable replacement might be found at good hardware store. I bet that is where Boston Whaler found the door latch they're using.
vze2gbs4
Postby vze2gbs4 » Thu Apr 19, 2018 12:10 am
That is not a whaler-made part. Search for Perko 0559DP black plastic marine door catch.
Postby jimh » Thu Apr 19, 2018 7:59 am
Maybe this will be a suitable replacement:
https://www.boatersplus.com/perko-door- ... hjEALw_wcB
Riverdance
Postby Riverdance » Sat Apr 21, 2018 7:08 pm
Thanks for your help Ridge,VZE and JimH. That is the correct part#. You can also pick them up at West Marine also.
