Re: RACOR Filter: removing filter from manifold and bowl
Oldslowandugly
Postby Oldslowandugly » Thu Apr 16, 2020 4:47 pm
The RACOR fuel-water separator filter I am using is mounted flush to the transom. When I tried to use a RACOR wrench to remove the bowl, the wrench hit the transom. Even with the bowl off, a strap wrench can barely fit between the filter and the transom.
I decided to space the filter housing away on a block of mahogany.
Fig. 1. Relocated stainless hanger bolts; not shown, spacer block.
Then I cut the filter wrench down so it would fit around the bowl. I used a section of the big end to fully circle the bowl even getting some of the indents to engage the flutes. Then I secured them together with stainless machine screws and nuts.
Fig. 2. Modified RACOR wrench
My measurements were bad because then the tilted up motor hit the housing. I had to relocate the housing about 3/4-inch lower so the motor cleared it and I still had room to drain the bowl into small can.
Fig. 3. Engine clearance. Space block shown.
Now I can use the filter wrench and get the bowl off like it is supposed to.
Re: Re: RACOR Filter: removing filter from manifold and bowl
Postby Phil T » Thu Apr 16, 2020 4:54 pm
My filters were only hand tightened. Think the wrench is excessove
A strap wrench might be need if it was wicked cold and I had slimy hands.
Oldslowandugly
Postby Oldslowandugly » Thu Apr 16, 2020 4:59 pm
You are probably right: the wrench likely is not always necessary
I hand tightened the filter, too. But the first time I tried to remove it the filter and bowl would not budge. I finally got a strap wrench around the filter and took them both off together. Then I had to put the filter in a big vise and use the wrench to get the bowl off. It was really stuck on. I used oil on the gaskets so I don't know why it was so hard getting them apart.
Postby jimh » Thu Apr 16, 2020 5:48 pm
Through-bolting the filter manifold to the transom is probably not necessary. Using self-tapping stainless steel fasteners into the wood reinforcement of the transom would be sufficient to hold the filter.
Mounting the filter so close to the engine is also probably not the best idea, as you found, due to problems with interference when the engine is tilted up.
I installed a RACOR fuel-water separating filter with clear bowl probably 10-years ago. I have not had the pleasure of trying to remove the filter media or the bowl. I have never seen any water in the bowl. I have a new filter element and may try to install it this Summer. I hope it spins off easily by hand, and same for the clear bowl.
Oldslowandugly
Postby Oldslowandugly » Thu Apr 16, 2020 9:16 pm
Yes, I agree that is not the ideal location. But on this boat flat mounting surfaces are rare. Moreover any fuel leaks can then drain out the scuppers instead of dripping into the boat itself.
Jim--I hope you have room to turn the RACOR wrench or even the strap wrench. I had a miserable time getting them off. The bowl is plastic and even with the filter in a vice it was very hard to get it off without damage. The modified bowl wrench is shown below.
Fig. 4. Modified RACOR bowl wrench
ConB
Postby ConB » Fri Apr 17, 2020 1:34 am
Use a filter strap wrench to remove filter and bowl. Use strap wrench and Racor wrench to separate filter and bowl. Reassemble bowl, filter, and base; hand tighten with light coat of oil on gaskets.
Fig. 5. Lisle 54400 Swivel Grip Oil Filter Wrench
https://www.amazon.com/Lisle-54400-Swivel-Filter-Wrench/dp/B0009OMYAG
--Con
1969 13 / 30hp Johnson tiller
Postby jimh » Fri Apr 17, 2020 6:43 am
The (unmodified} Racor RK 22628 REPL KIT, BOWL WRENCH tool is shown below.
Fig. 6. RACOR filter bowl wrench.
This tool is clearly designed to be used on several different diameter circular bowls.
Compare at: https://www.racorstore.com/index.php/catalog/product/view/id/10956
Postby jimh » Fri Apr 17, 2020 6:45 am
CON--I have that exact LISLE filter wrench, and have used it many times to remove filters from very tight spaces where the arc of rotation of the wrench is limited to a few degrees. It is an excellent tool.
ConB
Postby ConB » Fri Apr 17, 2020 9:47 am
Home made Racor tool.
Oldslowandugly
Postby Oldslowandugly » Fri Apr 17, 2020 3:19 pm
"This tool is clearly designed to be used on several different diameter circular bowls." --Agreed. Where in the world would that huge wrench fit and be able to clear the mounting surface?!? Only the biggest filter it fit would be able to swing it. Maybe if the filter was mounted to an overhead and the bowl/filter hung down with a large area around it. That is why I modified the wrench to fit my space. It being made of plastic and stainless screws I can leave it and a spare filter on the boat for emergencies without fear of it rusting. When else does a filter clog and fail?
