180 DAUNTLESS Engine Removal: Step-by-step Instructions180 Dauntless
tlsch377
Postby tlsch377 » Thu Jun 25, 2020 9:34 pm
Give me step-by-step instructions for pulling a Mercury OptiMax 135-HP engine from the [transom] of a 180 Dauntless.
I want to replace the mechanical steering system, including the helm.
This boat has the SmartCraft gauges. The wiring, hoses, and cables all pass through the same stern passage.
Re: 180 DAUNTLESS Engine Removal: Step-by-step Instructions180 Dauntless
Postby jimh » Fri Jun 26, 2020 8:19 am
Step 1: obtain the engine lifting accessory for attachment to the flywheel.
Postby Phil T » Fri Jun 26, 2020 9:47 am
You don't need to derig the engine.
Simply support the engine, loosen the bolts and angle the engine to port so you can remove the steering rod.
