Bimini For Outrage 22' 1988
fina
Postby fina » Mon Jun 29, 2020 11:45 am
Would a Wm. J. Mills & Co. Bimini from a 1997 Outrage 24' work on an Outrage 22' 1988?
Re: Bimini For Outrage 22' 1988
Postby jimh » Mon Jun 29, 2020 11:56 am
I doubt a Bimini for another model would be an exact fit on a different model. You can contact the Wm. J. Mills & Co. of Greenport, New York and ask them, inasmuch as they made canvas for both boats.
The canvas from Mills for an OUTRAGE 22 was called a FLYING TOP (small) or SUN TOP (large). The FLYING TOP is part of a WEATHER PROTECTION SYSTEM:
  • Flying Top
  • Windshield
  • Port Side Curtain
  • Starboard Side Curtain
  • Foward Shelter
  • Aft drop curtain
The SUN TOP was not integrated with other weather canvas.
Postby biggiefl » Mon Jun 29, 2020 1:36 pm
It will fit if the width is correct and the height is good for your needs. Biminis are rarely built for aa single hull as the bows can expand or contract a few inces in width to accommodate mounting spots. Your hull is 7.5' wide so you need roughly a 84" wide frame +/- a couple inches. Where are you located?
Postby Phil T » Mon Jun 29, 2020 2:04 pm
Nick -
I recall Bill is out on "the island", probably within an hour of Mills.
fina
Postby fina » Mon Jun 29, 2020 2:19 pm
Yes, on Long Island
fina
Postby fina » Mon Jun 29, 2020 2:21 pm
I believe the Bimini for the 24' is about 8' 5"
Postby biggiefl » Mon Jun 29, 2020 2:48 pm
Too wide, you can squeeze a couple few inches but not 18 or so.
