Assess Damage to 1968 13-footer
IgbyMac
Postby IgbyMac » Sat Mar 27, 2021 11:15 pm
Please give me some feedback on the extent of the damage you can see in the 1968 13-footer shown in Figures 1 to 8:
Fig. 1.
01 IMG_9330.JPG (95.34 KiB) Viewed 3425 times
Fig. 2.
02 IMG_9336.JPG (106.18 KiB) Viewed 3425 times
Fig. 3.
03 IMG_9338.JPG (114.2 KiB) Viewed 3425 times
BACK STORY: I know nothing about the extent of the damage to this boat. I am handy and confident to do basic cosmetic work including fibreglassing and painting, but I am not interested in doing structural transom replacements of the like. I went over the boat and looked for de-lamination on the hull or soft spots, or unusual sounds, but to my untrained ears and hands, all seemed solid.
[Moderator's notes: THREE different threads are combined into one. Please DO NOT START three different threads on the same topic. Eight attachments have been identified with a caption giving them figure numbers in order to be able to intelligently refer to the images in replies which are being solicited. Please do not attach eight images and give them no identification or caption. It is impossible for readers to make reference to a multitude of attached images in one thread unless they are identified in some manner with figure numbers.]
IgbyMac
Re: Assess Damage to 1968 13-footer
Postby IgbyMac » Sat Mar 27, 2021 11:17 pm
Fig. 4.
04 IMG_9342.JPG (106.55 KiB) Viewed 3424 times
Fig. 5.
05 IMG_9334.JPG (89.11 KiB) Viewed 3424 times
Fig. 6.
06 IMG_9345.JPG (69.63 KiB) Viewed 3424 times
IgbyMac
Postby IgbyMac » Sat Mar 27, 2021 11:22 pm
Fig. 7.
07 IMG_9344.JPG (67.37 KiB) Viewed 3425 times
Fig. 8.
10 IMG_9363.JPG (101.83 KiB) Viewed 3425 times
Q1: How much work am I looking at?
Q2: where can replacement lamps and bow railings be purchased?
ASIDE: I anticipate fabricating [new wood components] to original specifications using western red cedar.
Postby jimh » Mon Mar 29, 2021 10:39 am
IgbyMac wrote:Please give me some feedback on the extent of the damage you can see in the 1968 13-footer shown in Figures 1, 2, and 3.
Figure 1 show damage to the port stern quarter. The rub rail molding has been fractured. The structural joint between the hull and liner has been damaged.
In Figure 2 the rub rail has been damaged. The joint between hull and liner has been damaged.
In Figure 3 the keel has been damaged. The gel coat layer has been abraded away and the inner laminate layer is now exposed to water.
Figure 4 shows damage to the starboard stern quarter. The rub rail molding has been broken. There is apparent abrasion at the green-line joint between hull and liner at the transom top edge.
Figure 5 shows stress cracking at an oarlock; this is cosmetic not structural.
Figure 6 shows a blob of something in some location, probably some old sealant around some hole, perhaps an engine mounting hole. This is not damage. It is just a blob.
Figure 7 shows what may be the transom near the hand hold area with damage to the gel coat layer.
Figure 8 shows the same damage as seen in Figure 2. See my remarks above for Figure 2.
IgbyMac wrote:Q1: How much work am I looking at?
Enough to keep you busy for several months, assuming you work on it in your spare time.
IgbyMac wrote:Q2: where can replacement lamps and bow railings be purchased?
For advice on sources of OEM parts or recommended vendors, see
Original Equipment Manufacturers and
Recommended Vendors
http://continuouswave.com/whaler/reference/OEM.html
The website has a great deal of information other than posts in the forum. I recommend you begin at
and read the many articles presented in the REFERENCE section and other sections.
IgbyMac wrote:ASIDE: I anticipate fabricating [new wood components] to original specifications using western red cedar.
That will be a nice addition once you get this hull fixed. I think you should concentrate on the hull repairs and hold the new wood interior fabrication in abeyance.
IgbyMac
Postby IgbyMac » Mon Mar 29, 2021 11:35 am
Thank you kindly. That is a VERY nice breakdown of where I stand, and where I can pursue help.
Postby jimh » Mon Mar 29, 2021 12:48 pm
Read more about the green line joint at
viewtopic.php?f=4&t=6209&p=36312
IgbyMac
Postby IgbyMac » Mon Mar 29, 2021 4:42 pm
So much to learn about these legendary boats. Thanks again. And I welcome anyone chiming in with their two cents of experience, tips, ideas or thoughts on how best to go about restoring this classic.
