OEM-quality Replacement Fuel Tank Fabricator in Upstate New York
jongreene607
Postby jongreene607 » Mon Apr 06, 2026 12:03 pm
Q1: what are the specifications for a new fuel tank of 63 to 65 gallons-gallons that will fit a 1979 OUTRAGE V-20?
Q2: what vendor in upstate New York can fabricate an OEM-quality replacement fuel tank for a 1979 OUTRAGE V 20?
Q3: between plastic and weded aluminum sheet, which material is preferred for fabrication of a replacement fuel tank for a 1979 OUTRAGE V-20?
BACKSTORY
My son and I are renovating a 1979 Boston Whaler Outrage V-20. We plan to replace the internal fuel tank this year and re-foam.
—Jon Greene
Re: OEM-quality Replacement Fuel Tank Fabricator in Upstate New York
Postby jimh » Tue Apr 07, 2026 9:13 am
Contact FLORIDA MARINE TANKS for a quote for a new fuel tank. They will know the exact specifics for your older Boston Whaler boat, but do not expect them to send you a free detailed drawing. If the existing tank is made from welded aluminum sheet, they were the OEM provider.
Also, the OUTRAGE V-20 fuel tank has an asymmetrical shape. See the REFERENCE article on that hull at
https://continuouswave.com/whaler/reference/V20Outrage/
As for a fabricator of custom small boat below-deck fuel tanks in plastic and aluminum in a particular geographic region of a particular state, you should conduct your own inquires. The website has never attempted to collect information with those particular specific delimiters.
Try asking at GROK.COM. That is by far the best modern AI enhanced web search site.
