2004 160 DAUNTLESS: Location of Fuel Tank Level Sender
cobovn
Postby cobovn » Wed Jul 08, 2026 1:41 pm
Q1: on a 2004 160 DAUNTLESS where is the fuel tank level sender located?
I want to access the fuel tank level sender in order to assess if the problem with the fuel tank level gauge indicator jumping between EMPTY and 1/3-FULL is due to an electrical problem or a mechanical problem
ASIDE
One owner with a 2003 [160 DAUNTLESS to me the fuel tank level sender isolated] under the pilot's seat, but I'm not sure how to access it through the livewell.
[Moderator’s note: This author revived two older dormant threads on very similar topics to ask the same questions, essentially starting three simultaneous concurrent discussions on the same topic. Creating three simultaneous concurrent discussions on the same topic is a very poor way to get a discussion going smoothly in a single thread as any replies could be spread among the three. The two older revived threads are returned to dormant status and the reviving post removed.]
Re: 2004 160 DAUNTLESS: Location of Fuel Tank Level Sender
Postby Jefecinco » Thu Jul 09, 2026 10:03 am
cobovn wrote:Q1: on a 2004 160 DAUNTLESS where is the fuel tank level sender located?
First locate the sending unit cables in the console. With the ignition on have a helper observe the fuel gauge while you move the cables around. If the reading is affected by moving the cables that indicates [the cause of the fluctuating tank level indication] is electrical.
If [the cause of the fluctuating tank level indication] is electrical, then check the connections at the gauge by removing the cables, cleaning the terminals and reconnecting the cables. Then repeat the earlier test.
Postby jimh » Thu Jul 09, 2026 10:28 am
If you are asking about a fuel tank gauge that is an electrically operated remote gauge, the fuel tank level sender will be located on the top of the fuel tank.
Typically access to the fuel tank level sender will be via a removable deck access plate, typically a circular plate that can be pried out from the deck.
The fuel tank level sender typically is connected to a float mechanism in the fuel tank, and is a variable resistance. For details of the resistance values associated with the tank level, refer to
Tank Sender and Trim Sender Resistance
https://continuouswave.com/forum/viewto ... f=9&t=3043
For details of the wiring of a remote electrical fuel tank level gauge that connects to a fuel tank level sender on the fuel tank, see
Fuel Tank Level Sender Wiring
https://continuouswave.com/forum/viewto ... 740#p46728
See the section that begins with a paragraph "In a Boston Whaler boat the electrical wiring..."
Also continue in that archived thread and read more at
https://continuouswave.com/forum/viewto ... 740#p46734
For further details about he exact location of the fuel tank sender unit you can obtain detailed drawings that show all elements of the boat from Boston Whaler. Start your search for the drawings at
https://www.bostonwhaler.com/resources- ... nance.html
Enter the year, family, model information, and you can find drawings like these:
https://www.bostonwhaler.com/content/da ... 2-2004.pdf
While the electrical wiring is not shown in the assembly drawings, the small circular plate on aft end of the tank appears to be where the float sender is located. A circular deck access plate appears to align with that area of the fuel tank.
Postby jimh » Thu Jul 09, 2026 12:29 pm
If the fuel tank level sender is actually located at the extreme aft end of the fuel tank, the wide swings in tank level being seen on the remote electrical gauge could be due to fuel sloshing fore and aft in the tank.
