1988 REVENGE 22: Gunwale Cap Joint
REVENGE22WD
Postby REVENGE22WD » Wed Nov 11, 2026 9:43 pm
Q1: [On an unspecified model year] REVENGE 22 [as seen in Figure 1 where the rub railing has been removed to reveal the joint line] should the joint between the gunwale cap and the hull be continuously sealed along its entire length?
Fig. 1. Gunwale cap to hull joint.
[Moderator's note: when discussing a specific boat, please include the model year using four digits].
Re: [Unspecified Model Year] REVENGE 22: Gunwale Cap Joint
Postby jimh » Thu Nov 12, 2026 9:47 am
Figure 1 appears to show the gunwale cap was fastened to the hull with a number of screw fasteners, and when the rub rail was installed, more fasteners were added to hold the rub rail plastic track to the cap and hull.
Q2: are you asking if some sort of sealant should be applied to the joint line between the gunwale cap and the hull?
REVENGE22WD
Re: 1988 REVENGE 22: Gunwale Cap Joint
Postby REVENGE22WD » Thu Nov 12, 2026 1:27 pm
Yes, exactly. I’m asking whether the joint between the gunwale cap and the hull should be sealed with marine sealant, such as 3M 5200, to prevent water intrusion.
Postby jimh » Thu Nov 12, 2026 6:00 pm
REVENGE22WD wrote:I’m asking whether the joint between the gunwale cap and the hull should be sealed with marine sealant, such as 3M 5200, to prevent water intrusion.
I would NEVER use 3M5200 as a sealant. That product is a super-strong adhesive than can tolerate water immersion.
I can't speak with authority, but my impression is that at the Boston Whaler factory there probably was no sealant applied to that gunwale cap to hull joint on a REVENGE 22.
If you can see gaps in the gunwale cap and hull joint on your particular boat, now that it has been 38-years since those two were fastened together, you could apply a sealant. As for a choosing a sealant, I would probably use marine grade silicon caulk.
Q3: are you seeing any big gap openings between the hull and the gunwale cap at the joining line?
Q4: are you seeing any evidence that at one time there was a sealant used on that joint line?
REVENGE22WD
Postby REVENGE22WD » Thu Nov 12, 2026 7:48 pm
jimh wrote:Q3: are you seeing any big gap openings between the hull and the gunwale cap at the joining line?
There is no unusually large gap; all the gaps appear to be uniform in size.
jimh wrote:Q4: are you seeing any evidence that at one time there was a sealant used on that joint line?
I also don’t see any evidence that sealant was ever applied at the factory.
I would like to seal these joints, but I’m curious why Boston Whaler left them unsealed from the factory. Could it be intentional for water drainage, ventilation, or another design reason?
What do you think was the reason for leaving these joints unsealed? I want to make sure sealing them won’t cause any unintended problems. Thank you.
Postby jimh » Fri Nov 13, 2026 9:35 am
REVENGE22WD wrote: I’m curious why Boston Whaler left [the joint line between the hull and the gunwale cap] unsealed from the factory. Could it be intentional for water drainage, ventilation, or another design reason?
Your two guesses are the same as mine: let air in and let water out.
As for other reasons, perhaps Boston Whaler recognized that there could be some flexing of the the hull or the gunwale cap at the joint line, and if they tried to seal the joint it could have allowed some stress to build up and crack the gel coat. The gel coat layer often will develop stress cracking, particularly if the thickness of the gel coat layer becomes built up and it can no long flex slightly in response to stresses applied.
Alternatively, omitting any sealant could just could have been a concession to production efficiency and time saving. A sealant would need at least a day to cure to solid, which would tend to prevent any other work being done on the hull or liner.
