I am working on a 1963 13-footer tha I have owned it for three days. [unnecessary ellipses deleted] I know very little about boats. I have done some bondo on cars.
There is an ugly battleship gray paint on the inside. It has many cracks and is flaking off in about 20-percent of the surface area. I have chipped and sanded on it for two days . Now I have a very uneven surface. Also found lot of cracks in the gel coat. I guess what you guys call spider cracks. Also in the grove between the anti slip floor and sides I found some holes.
I should also say the foam is wet under the hole I found.
Can I remove the loose stuff and lay a whole new layer of fiber glass cloth to make a new surface?
How much would that cost?
Is it done?
How much water is too much?
I am working outside so should I cover it every time it rains?
I have spent some hours reading archives: great info--thanks
I am wondering if this boat is too far gone to fix.
Mostly just want to go fishing. I do not care if it looks brand new . I just want a safe boat.
Thanks , Dan
Fiberglass Repairs Atop Painted Surfaces
Re: Fiberglass Repairs Atop Painted Surfaces
When making a repair, you want to abrade the hull or deck surface so that all loose material is removed.
If the gel coat surface of the hull or cockpit have been given a top coat of just paint, trying to make a repair adhere to the painted surface is not a good method.
Read the two articles on making repairs in the REFERENCE section. Here are links to them:
by Taylor Clark
http://continuouswave.com/whaler/refere ... epair.html
Another good source of advice and methods for repair of fiberglass boat is the WEST System Repair Guide. See
Fiberglass Boat Repair & Maintenance
http://www.westsystem.com.au/west_syste ... aintenance
by Taylor Clark
