Fiberglass Repair Advice Needed
BennyF
Postby BennyF » Sun Jul 24, 2016 7:09 pm
I am a do it yourselfer and working on a project. I have never worked with fiberglass, gelcoat, or anything in that area but I am about to tackle a project and need help. I have a fiberglass trike body that needs a few drilled holes patched and needs to be painted. The original gelcoat was painted over. I have removed the paint and have the original gelcoat (with tons of flake) exposed. It is pitted real bad. What is the best way to patch the holes (1/4" and smaller)? And I was thinking of using a polyester resin or a gelcoat to prime and fill the pitting. Then spray automotive paint. How should I tackle this? Please let me know if this plan will work or suggest the best route.
Re: Fiberglass Repair Advice Needed
Postby jimh » Wed Jul 27, 2016 9:14 am
See
If the original gel coat finish has already been top-coated with paint, there is no reason to use gel coat resin. Just fill small holes with epoxy. See
