77-gallon Fuel Tank Dimensions
hrokyta
Postby hrokyta » Thu May 09, 2019 5:05 pm
THIS TOPIC HASD BEEN SEPARATED FROM ANOTHER THREAD. DO NOT JOIN A THREAD ONLY TO CHANGE THE TOPIC OF THE THREAD TO SOMETHING NEW.--jimh
I am in the process of restoring a 1986 Outrage 20. I am considering a fuel tank replacement. I need the technical drawing for a 77-gallon fuel tank that measures 70-inches long and 22-inches wide. Any info is greatly appreciated.--Honza
Re: 1989 Boston Whaler 22 Outrage Restoration
Postby Phil T » Fri May 10, 2019 7:45 am
Unfortunately, drawings are not available to the public.
The original manufacturer, Florida Marine Tanks (FMT) in Henderson, SC still produces replacement tanks that are the factory specifications. If you are on the eastern seaboard, albeit south of Boston, I would order a tank from them. If farther away, the shipping costs make it expensive.
Many owners remove the existing tank and have a local fabricator make you one.
https://floridamarinetanks.com/quote/
You can search the archives for many threads on how to techniques.
Re: 77-gallon Fuel Tank Dimensions
Postby jimh » Fri May 10, 2019 10:30 am
To have an exact replacement tank fabricated, remove the original tank and use it as a pattern or model for the replacement tank to be fabricated.
