1999 Dauntless 14 fuel tank leak
AndrewJaxFL
Postby AndrewJaxFL » Mon Jul 06, 2020 2:57 pm
I have a 1999 Dauntless 14 and am looking for advice to repair a leak where a sending unit goes into the tank.
I assume tank is original but not sure; it is plastic
I have tried new gaskets and permatex gasket sealant.
Any advice would be great.
Re: 1999 Dauntless 14 fuel tank leak
Postby Phil T » Mon Jul 06, 2020 5:05 pm
Pictures please.
Postby jimh » Tue Jul 07, 2020 11:36 am
Non-metal fuel tanks are often made with a plastic that will be difficult for most adhesives to bond to. Fittings are usually held in place by compression.
Gasoline is a very good solvent. Any sealer must be impervious to gasoline and blended ethanol gasoline fuels, and be able to get adhesion to the tank material.
Contact the tank manufacturer for advice.
Contact Boston Whaler for advice on the leak and the tank manufacturer.
A new fuel tank may be the best solution. Any repair may create risk.
