1970 13-foot Hull Repair: Epoxy v. Polyester Resin
Posted: Thu Nov 12, 2020 9:20 am
A 1970 13-foot hull has several cracks and holes. I have read about hull repair but am still not clear on a few items.
Based on what I read, it seems that epoxy resin over fiberglass mat is the best approach for patching holes, and I am familiar with the process. However, I was told by a reputable manufacturer to use polyester resin, primer, and bottom paint for below the waterline.
I've also read that gel coat resin doesn't adhere well to epoxy resin.
Q1; is epoxy resin the preferred resin for below-the-waterline hull repairs?
Q2: specific to below-the-waterline repairs, do you [apply] gelcoat over the resin?
Q3: Or, do you use primer and bottom paint over the resin?
In case anyone reading this thread is searching for related content, here are two good [articles hosted on CONTINUOUSWAVE.COM]:
http://continuouswave.com/whaler/reference/whalerRepair.html
The Epoxy Cure
http://continuouswave.com/whaler/reference/epoxyRepair.html
BoatworksToday is also a great resource.
The Epoxy Cure
