Trailer Bunk Brackets without Slots
SpongeBob
Postby SpongeBob » Sat Jul 22, 2023 1:40 pm
Q1: what vendor sells trailer bunk brackets with holes instead of slots to insert the bolts or U-bolts into?
ASIDE
I find it much easier to adjust all brackets to the same height or different heights in front and back using a bracket with holes. To count the holes to set the height of a bunk is easy. The only bunk trailer brackets I find online are brackets with a long slot at the top and a long slide at the bottom. Granted, these are infinitely adjustable, but I prefer the brackets with eight to 10 holes.
Jeff
Re: Trailer Bunk Brackets without Slots
Postby jimh » Sat Jul 22, 2023 10:03 pm
SpongeBob
Postby SpongeBob » Sun Jul 23, 2023 7:54 pm
Thanks Jim I appreciate the reply.
Those [trailer bunk brackets] do have holes but not the ones that I am looking for.
The [trailer bunk brackets] that I’m looking for are made out of U channel. They are just like the ones with slots but they have holes instead of slots.
I’m not sure that the ones you referenced are strong enough.
Jeff
SpongeBob
Postby SpongeBob » Sun Jul 23, 2023 8:35 pm
Jim, I want to thank you. I did some searching and found Jeff Rolfing’s video on setting up a trailer for a 13 Whaler. Jeff and I have conversed and he help me replace the floor and my 22 Outrage over 15 years ago so I trust him, and looking on his video the brackets that he used were identical to the ones you showed me. So again thank you I will be going to the ones you referenced.
Jeff
