Outrage 210 and Outage 190 Fabricating New Seat Bolster Brackets
fno
Postby fno » Tue Apr 09, 2024 9:43 pm
I own a 2015 Outrage 210. I am in the process of having all of the boat's vinyl bolsters and cushions recovered. In the process, I am going to make new brackets for the pilot seat bolster that hinges up and down.
The originals are made of painted aluminum and look like crap now and it isn't worth keeping them. I plan to make the same brackets from 316 stainless steel angle material sourced from McMaster-Carr.
I have not priced these brackets from Boston Whaler and I am not sure they are even available by themselves. From my last inquiry with Sue Lodell, the cushions and anything to do with them should be made out of gold, and not the plated kind.
So here goes: if anyone wants to replace their brackets for the seat bolster, let me know and I will make more than the one set I need. Making four or five in not much harder than just one set. The 316 SS materials are not cheap so the brackets will cost about $200 to $250 for the pair depending on how many I make. I only need one set for me and if others need some, all the better. If I can make them for less than those numbers the savings will be passed on as well.
I will add pictures of the one I have so you can see what you will get.
Re: Outrage 210 and Outage 190 Fabricating New Seat Bolster Brackets
Postby jimh » Wed Apr 10, 2024 10:42 am
Hi Frank--this sounds like a nice project. The resources that participants here have access to for fabricating parts are always quite amazing to me.
Postby Phil T » Wed Apr 10, 2024 12:14 pm
Frank - Are these the same ones you helped document for Adir a few years ago?
fno
Postby fno » Wed Apr 10, 2024 9:16 pm
Yes, these are the same ones. The originals are aluminum and corroded. My first plan was to sandblast the brackets and powder coat them. That runs me about $100 no matter how small the job is. The vinyl guy who does a lot of old cars and street rods informed me what I suspected. The sandblasting would remove too much metal and the powder coat would also only last so long. My angle is 316L so no worries there, the fasteners are 18-8 stainless which is less corrosion resistant but we will see as that is all I can find.
Postby Phil T » Thu Apr 11, 2024 9:32 am
Very interesting.
Look forward to how the project unfolds.
