My [2002 Mercury 25-HP FOURSTROKE BIGFOOT engine had] sat for many years as a utility boat for a municipality. The engine ran "great" for about two outings but now the engine is getting "white oil."
The head gasket looks "good."
I changed the thermostat.
I cleaned the carburetor.
The [2002 Mercury 25-HP FOURSTROKE BIGFOOT engine] runs "great."
Now I am putting back together the [2002 Mercury 25-HP FOURSTROKE BIGFOOT engine].
I see a double gasket used on the head gasket.
If [seeing a double gasket used on the head gasket] does not solve [the engine "getting white oil"] then [the next remedy to try] looks like I'm heading for the base gasket.
The engine block [of the 2002 Mercury 25-HP FOURSTROKE BIGFOOT engine] was made by Yamaha.
A Yamaha base gasket works.
[In a future post I will announce] the part number and report back if the head gasket solved [the problem with the engine getting "white oil"].
2002 Mercury 25-HP BIGFOOT FOURSTROKE: White Oil
guybk1@gmail.com
Re: 2002 Mercury 25-HP BIGFOOT FOURSTROKE: White Oil
Thanks for announcing that in the future you will post the part number of the Yamaha base gasket, and if that solved the problem of the engine "getting white oil."
I do not understand your sighting of "a double gasket". Is this sighting an observation of a mistake by some prior owner in servicing the engine?
