Q1: after patching various holes and painting with AWLGRIP 545 primer (or similar), and then sanding, will the primer coat be sufficient to fill and "repair" all the crazing?
Q2: If the primer paint is not sufficient, how can the crazing and cracking be properly repaired?
Q3: are both Alexseal or Awlcraft, compatible with the 545 primer?
Q4: between Alexseal or Awlcraft, which is better?
Q5: where can the after market console seen in the website page linked below be purchased?
https://fasseco.com/featured-boston-whaler/1983-boston-whaler-15-customsideconsole-tannler
BACKSTORY (LONG)
My neighbor had a 1985 Sport 15 that probably hasn't moved from the side of his house in 10 years, if not more, so I made him a deal and now it's in my driveway.
I spent my entire adult life lamenting that I never had a Boston Whaler boat while growing up in south Florida. Now with a 21-month-old and another one on the way, decided I needed to live vicariously through them.
The good news: [I am] thinking the foam is pretty dry because the boat hasn't seen the water in forever. [The hull does not] seem to have any water in it--based on my judgement of [the boat and trailer's total] weight when I was pushing around the trailer with boat on it.
Also, I don't see any water weeping out of the drain tube. Everything below the waterline seems solid, [and there are] no dings or scrapes.
The bad news: due to exposure to sun there is gel coat fading, there is gel cost grazing and cracking, the hull has bottom paint, and a lot things have been attached to the hull by screws over the years.
The restoration will be done slowly, and I am aiming for very high quality (as in the boat linked above in Q5).
I've done some glass and gelcoat work over the years, so I am not a novice. I will strip the boat of everything to get to a bare hull. I will remove the bottom paint. I will do all the fiberglass repair and preparation work, then I will hire a painter to stray the hull and cockpit. Then I will slowly put the boat back together. Finally, I will re-power with a new Yamaha F70 engine.
FIgures 1 to 6 show images (hosted elsewhere) of the boat in its present condition.
Fig. 1. No caption provided
Fig. 2. No caption provided
Fig. 3. No caption provided
Fig. 4. No caption provided
Fig. 5. No caption provided
Fig. 6. No caption provided
[Moderator's note: deleted a question asking for the opinions of the quality of a well-known vendor's products. That topic has been discussed extensively in many prior discussions. Use a search using the vendor's name to locate many prior discussions.]
