Pitot Tube Speedometer Calibration
hc803
Postby hc803 » Mon Sep 22, 2025 12:52 pm
Q1: can a Pitot-tube operated speedometer whose scale calibrations show up to 70-MPH be replaced with a new Pitot-tube speedometer with scale calibrations only up to 50-MPH and accurately show speed through the water while using the original water pickup on a 1987 Yamaha 90-HP engine?
BACKSTORY. The pitot tube in my 1987 Yamaha 90 two-stroke-poewr-cycle outboard engine never in the 15 years I've owned my boat [been] attacked [the the speedometer gauge]. I am currently in the process of cleaning out the pitot intake and refitting the nipple and [connecting the tubing to the original speedometer gauge whose dial reads up to 70-MPH that is installed at the center console of 1987 MONTAUK 17]. The original Yamaha speedometer is presumably non-functioning as the dial pointer indicator rests around 20-MPH at all times. I would like to replace it with a "50-MPH max" version as the boat has never seen speeds over 45-MPH.
Re: Pitot Tube Speedometer Calibration
Postby jimh » Mon Sep 22, 2025 5:33 pm
I asked the AI device at GROK.COM this question:
Q: Are all recreational boat pitot-tube speedometers that use the water pickup provided by a Yamaha engine interchangeable?
The AI device researched the question and gave this answer:
No, not all recreational boat pitot-tube speedometers that use the water pickup provided by a Yamaha engine are universally interchangeable. While many pitot-tube speedometers are designed with universal compatibility in mind, several factors can affect interchangeability, particularly when integrated with a Yamaha engine’s water pickup system. Here’s a detailed breakdown:
FACTORS AFFECTING INTERCHANGEABILITY
Water Pickup Location and Design:
Yamaha engines often have a built-in pitot tube or water pickup port integrated into the gearcase or lower unit of the outboard motor. This pickup feeds water pressure to the speedometer through a tube. The design, size, and location of this pickup can vary across Yamaha engine models and horsepower ratings, which may affect compatibility with aftermarket or universal pitot-tube speedometer kits.
Some speedometers rely on an external pitot tube mounted on the boat’s transom, which may not directly interface with the Yamaha engine’s internal pickup without additional tubing or adapters.
Tubing Size and Connection:
The tubing size (diameter and length) and the type of connector used to link the Yamaha water pickup to the speedometer gauge can differ. For example, some universal pitot kits, like those from SEACHOICE or asdmm, use marine-grade PVC tubing (often 20 ft) with specific barb sizes or connectors. If the Yamaha engine’s pickup tube has a non-standard fitting, an adapter or custom connection may be needed.
Speedometer Calibration:
Speedometers are calibrated to interpret water pressure from the pitot tube into speed readings. A speedometer designed for one brand or pickup system may not be calibrated correctly for the water pressure provided by a Yamaha engine’s pickup, leading to inaccurate readings. For instance, a forum post noted that pitot tubes can be less accurate than GPS speedometers and may require specific calibration for the boat’s setup.
Mounting and Installation:
Universal pitot kits, such as the Marine Boat Speedometer Pitot Kit or the ISURE MARINE Kick-up Pilot Tube, are designed to fit most brands with standard mounting holes, often requiring no modifications. However, if the Yamaha engine’s water pickup is integrated into the gearcase, an external pitot may not be necessary, and retrofitting a different speedometer could require rerouting tubing or modifying the connection to the engine’s pickup.
Some boats with Yamaha engines may have unique transom or hull configurations, which could complicate the installation of a non-Yamaha-specific speedometer.
Model-Specific Variations:
Yamaha outboards vary by model and year, and the water pickup system may differ (e.g., location on the gearcase, pressure ratings). A user on a Yamaha Outboard Parts Forum mentioned difficulty locating the pickup tube on their engine, indicating that model-specific knowledge is often needed to ensure compatibility.
Brand-Specific Gauges:
Some speedometers are designed to work seamlessly with Yamaha’s instrumentation (e.g., Yamaha Command Link or analog gauges). Non-Yamaha gauges may not interface correctly with the engine’s pickup without adjustments or additional components. For example, a Key West Boats forum user reported inaccurate speedometer readings on a boat with twin 200HP Yamahas, suggesting potential mismatches or clogs in the system.
Universal Pitot Kits and Compatibility
Many aftermarket pitot-tube kits, such as those from SEACHOICE, asdmm, or Aspaton, claim universal compatibility and can often be adapted to work with Yamaha engines. These kits typically include a pitot tube, 20 ft of tubing, and mounting hardware, with features like a kick-up mechanism to prevent damage. They are designed to fit standard mounting plates and work with most marine speedometers up to 80 MPH.
However, even with universal kits, you may need to verify that the tubing diameter matches the Yamaha engine’s pickup port and that the speedometer gauge is compatible with the water pressure provided by the engine’s pickup.
Postby jimh » Mon Sep 22, 2025 5:40 pm
hc803 wrote:The original Yamaha speedometer is presumably non-functioning as the dial pointer indicator rests around 20-MPH at all times.
I don't think that an at-rest reading of 20-MPH on a pitot-tube speedometer indicates the device is non-functioning. More likely this indicates that with the 70-MPH top speed range as the dial calibration, the device is not going to start to show actual boat speed until the boat is going at least 20-MPH.
If there is a Yamaha speedometer available and its top speed indication is suitable for you (at 50-MPH), and it is listed as an accessory for your particular Yamaha engine, then that speedometer should work with water pickup or pitot-tube in your engine.
If you just want to fill in a large circular hole in the dashboard with speedometer gauge you could buy a non-Yamaha speedometer that includes its own water pick-up pitot-tube assembly to be mounted on the boat transom. They sell for about $110.
Or a better option in my opinion: get boat speed as Speed-Over-Ground from a GNSS receiver that you likely already have on the boat in the form of a chart plotter.
These days the Pitot-tube speedometers are generally only used in competition ski boats because they want to know speed through the water, not speed over ground, during water skiing competitions which are conducted at specific and various boat speeds.
Also, some anglers who like to troll at very low speeds might use a pitot-tube speedometer because they also are most concerned with actual speed through the water, not speed over ground.
But if knowing speed over ground is sufficient for you, the use of a GNSS receiver to provide the data seems like the best option.
