1983 Montauk 17 Re-power 100-HP
philippestuebi
Postby philippestuebi » Sat Apr 16, 2016 2:40 am
[I] need to re-power my 1983 [Boston Whaler MONTAUK 17] and would like to install a new Mercury 100-HP FOURSTROKE [BASED ON 2.1-LITER BLOCK] [The] weight of the engine without propeller and liquids is 359-lbs.
What do you think?
Re: 1983 Montauk 17 Re-power 100-HP
Postby jimh » Sat Apr 16, 2016 9:20 am
In the USA, I think Brunswick is selling these Mercury-brand FOURSTROKE BASED ON 2.1-LITER BLOCK models in 75, 90, and 115-HP versions. If they have a 100-HP version it must be a model sold overseas.
The general attributes of the FOURSTROKE BASED ON 2.1-LITER BLOCK are the topic of a concurrent discussion. See
Engine Choice in 115-HP
viewtopic.php?f=7&t=676
Since you mention the weight, I infer that it is the weight you are soliciting comments about. The appropriate engine weight for use with a MONTAUK has been a continual topic of discussion. There is a wide range of opinion on weight. Here are some prior discussions:
From 14-years ago
Transom Weight and HP Ratings
http://continuouswave.com/ubb/Forum4/HTML/000749.html
From 12-years ago
Maximum Engine Weight
http://continuouswave.com/ubb/Forum4/HTML/002449.html
From 10-years ago
Storm Story: July 17, 2006, Manitoulin Island
http://continuouswave.com/ubb/Forum1/HTML/013113.html
From 2-years ago
New Mercury 90 on a Classic Montauk
http://continuouswave.com/ubb/Forum4/HTML/008092.html
Peter
Postby Peter » Sun Apr 17, 2016 8:19 am
jimh wrote:In the USA, I think Brunswick is selling these Mercury-brand FOURSTROKE BASED ON 2.1-LITER BLOCK models in 75, 90, and 115-HP versions. If they have a 100-HP version it must be a model sold overseas.
In Europe, Mercury sells the 2.1L FourStroke line as 80, 100 and 115 HP models. Yamaha does the same, the F75 and F90 models marketed and sold in the U.S. are F80 and F100 models in Europe.
Mr C
Postby Mr C » Sun Apr 17, 2016 11:06 am
If 100hp is a must, get yourself a Honda BF100. Only badged 100hp outboard available in the U.S. market.
http://marine.honda.com/outboards/motor-detail/BF100
philippestuebi
Postby philippestuebi » Sun Apr 17, 2016 2:29 pm
thanks to everybody for precious inputs!
Peter
Postby Peter » Sun Apr 17, 2016 3:40 pm
Mr C wrote:If 100hp is a must, get yourself a Honda BF100. Only badged 100hp outboard available in the U.S. market.
If a Honda is a must, get the 90. The 100 requires 93 octane rated fuel.
kwik_wurk
Postby kwik_wurk » Thu Apr 28, 2016 1:03 am
Quick note on the Mercury 2.1L, yes it is the same block for the 75/90/115 hp models in the US. The control module to up a 75 or 90 engine into 115hp is not that expensive if you really want the top end performance. (Its a doable modification, i can't comment on what it does to warranty or liability.)
I am going on a boat test Friday on a 2.1L 90hp version mainly to see the lowest RPM it will go with troll mode.
From what I have been told from a few owners with the 2.1L 90 is the unit is solid power at all RPM's. There really are no noteable power bands that some engines have and has plenty of low end power/torque.
