Re-powering a 1988 OUTRAGE 22 CUDDY
JoeNorm
Postby JoeNorm » Sun Oct 11, 2026 10:42 am
Q1: for re-powering a 1988 OUTRAGE CUDDY 22 that currently has a 1988 Johnson 225-HP engine with a four-stroke-power-cycle engine, between a 200-HP and a 225-HP , which would be preferred?
Re: Re-powering a 1988 OUTRAGE 22 CUDDY
Postby jimh » Sun Oct 11, 2026 11:31 am
Before suggesting engines for re-power, I will comment on the current engine:
The Johnson 225-HP engine from c.1988 could be a very nice engine. I recommend you inquire about the sort of gasoline fuel that has been used. This engine (and the boat fuel system) are probably NOT very tolerant of ethanol-gasoline blended fuels. Here in Michigan state law requires that non-ethanol 90-Octane gasoline fuel be available for use on boats. Avoiding all diluted gasoline with 10-percent (or higher) ethanol content is very highly recommended to avoid problems with outboard engines designed and manufactured before the ethanol dilution craze took over the USA in the 2000's (due to the farm lobby and ethanol producers political influence, not from actual science).
I list of a few minor problems I encountered with my OMC 225 V6:
  • intermittent starter solenoid (fixed for $23)
  • intermittent ignition Power Pack (fixed for $225)
  • leaking fuel line vacuum sensor (fixed for less than $50)
  • fuel-oil automatic mixing pump (VRO) replacement (about $300)
Also a c.1988 engine will have the older red Amphenol rubber body connector wiring harness, which has been obsolete since c.1996.
When this V6 two-stroke-power-cycle carburetor engine is in proper tune, and its simple engine ignition controller is working properly, and the fuel line is properly primed using a working primer bulb, the engine should start from cold typically on the first crank-over (or second), run at fast idle until operating temperature is reached, and produce some smoke in the exhaust--primarily depending on what type and grade of two-stroke TCW oil was being used. Using a synthetic oil can reduce smoke in the exhaust significantly.
The fuel economy at cruising speeds and faster was reasonably good, generally over 2-MPG. The only drawback to this six-cylinder six-carburetor two-stroke-power-cycle engine regarding fuel use was at slow speed operation. The fuel economy at no-wake speeds was worse than at cruise. It is just the nature of these engines to waste a lot of gasoline idling along.
The notion that if you re-power with a modern engine you will recover the cost of the new engine in savings from reduced gasoline usage is not likely to work out for you, unless you run the boat hundreds of hours every year, and you buy gasoline at very expensive marina fuel docks at ridiculous prices. This outcome is due to the cost of a new engine, which often required thousands of dollars in new controls, new gauges, new propeller, new engine harness, and labor for the changeover and installation. A new 200 to 225 engine will cost well over $20,000 installed and rigged—if not more. You will have to do a helluva lot of boating to recover $20,000 in saved gasoline purchases.
If you MUST get a modern engine, you should try to buy one already on a boat, like you hypothesized perhaps five-years-old or newer.
Re-powering 1998 OUTRAGE 22 CUDDY
Postby jimh » Sun Oct 11, 2026 3:43 pm
JoeNorm wrote:Q1: for re-powering a 1988 OUTRAGE CUDDY 22 that currently has a 1988 Johnson 225-HP engine with a four-stroke-power-cycle engine, between a 200-HP and a 225-HP , which would be preferred?
In some brands their 200-HP engine is a four-cylinder in-line, and the 225-HP is a larger displacement V6. The V6 should be the better fit.
If there is a V6 200-HP model, and there is significant cost savings compared to buying the same V6 block rated at 225-HP, then the 200- HP V6 might be an option.
JoeNorm
Postby JoeNorm » Mon Oct 12, 2026 9:27 pm
I don't believe I would ever recoup the costs of a new engine through fuel-cost savings.
Re-powering [with a modern outboard engines] would be more about
  • reliability--maybe a false assumption;
  • quieter operation, and
  • better fuel economy.
Postby jimh » Wed Oct 14, 2026 10:16 am
A further consideration with investing in a new outboard engine:
Q2: how long to you expect to keep the boat?
Once a new engine is purchased, the value added to the boat will certainly increase, but the gain in value is very unlikely to match the total cost of the re-powering. If you decide to sell the newly-re-powered boat in a few years, the new engine cost will probably not be repaid in a higher selling price. On that basis, re-powering works best if you plan to keep the boat for long term use. You will have the enjoyment of running the new engine for many years, which will provide you with most of the benefit of having a "new" engine.
In my own case, in 2009 I took off a very nice 17-year-old 1992 Evinrude 225-HP V6 and replaced it with a 2010 model year E-TEC 225 engine. I have been enjoying using the "new" engine for 17-years, and I have no plans to replace it.
One unforeseen outcome: Evinrude abandoned the outboard engine business. That makes the current value of a 17-year-old E-TEC a bit less than one might have hoped for.
