2005 MONTAUK Mercury 90-HP FOURSTROKE
WYEMILLSWHALER
Postby WYEMILLSWHALER » Sun Jun 21, 2020 4:19 pm
[MOVED to PERFORMANCE for discussion and author notified--jimh]
[Give me] advice [on propeller selection for a 2005 MONTAUK of unspecified length--please always mention the model length].
A BLACK MAX three-blade aluminum 13-1/4 x 17-pitch [allows the 2020-production year Mercury 90 FOUSTROKE engine to accelerate] to only 5,100 RPM with [proper engine] trim.
I [believe engine speed at full-throttle] should be around 5,500-RPM.
Any help would be great. Thanks
Re: 2005 MONTAUK Mercury 90-HP FOURSTROKE
Postby jimh » Mon Jun 22, 2020 10:35 am
The owner's manual that was provided with your 2020 production epoch Mercury 90 FOURSTROKE will list the recommended engine speed range for full-throttle operation. Please pass along that important information by a reply post what the manual says.
Postby jimh » Mon Jun 22, 2020 10:39 am
In order to offer advice on propeller selection, readers will need to know more information that you must provide:
--what is the length of the 2005 MONTAUK boat you are asking for advice?
--what is the boat speed in statute miles0per-hour at maximum throttle?
--what is the gear ratio of the engine?
--how was boat speed measured?
--what were the environmental conditions during the on-the-water testing, such as air and water temperature, winds, current, sea state
--what was the load of passengers, fuel, gear, aboard when testing?
Rascal
Re: 2005 MONTAUK 2020 90 HP MERC 4STRK
Postby Rascal » Mon Jun 22, 2020 10:51 am
In addition to the information Jim mentioned, it would help to know what your goals are: Will you typically have 1 person or 7 people onboard? Maximize top speed, hole shot, or fuel economy? Do you have bottom paint?
As a comparison, my 2015 170 Montauk with 90-HP FOURSTROKE EFI came from the factory with a Vengeance three-blade prop 13-1/8 x 16-pitch (PN 48-16986). It reaches the maximum RPM range ( about 5750-RPM). It's a well rounded prope;;er that works well for two to seven people on board and for water sports or cruising. Reducing your pitch to 16 from 17 will increase engine speed by about 200-RPM. Moving to a stainless propeller from an aluminum propeller will also increase engine RPM some. One or both of these changes will put you more in the middle of a 5000 to 6000 maximum RPM range--the same maximum range as my engine.
Rascal (Scott)
2015 170 Montauk
WYEMILLSWHALER
Postby WYEMILLSWHALER » Mon Jun 22, 2020 11:05 am
2005 17 MONTAUK
2020 90-HP Mercury FOURSTROKE
No more than three people on board.
I tired a 17-pitch still didn't hit the 5500 RPM
Thanks for the help
Postby Phil T » Mon Jun 22, 2020 12:55 pm
The Mercury 90 hp engine offered on the Montauk 170 has changed three times since the boat model was first introduction in 2002.
From 2003-2018 the Mercury 90 FourStroke had a 2.33 lower unit.
For the 2019 and later years, the Mercury 90hp FourStroke has a gear ratio of 2.07. The Command Thrust option has 2.38 gears.
I would recommend the 13.15 x 18 Mercury Vengance for the 2020-production epoch Mercury 90 FourStroke on a classic Montauk 17 mounted at least two holes up. This size recommendation only applies to the specified make and model of propeller listed.
Aside: In checking specifications, note the current Montauk 170 II has a dry weight that is twice as much as the classic Montauk 17. 950-lbs v. 2050-lbs.
Postby jimh » Mon Jun 22, 2020 5:37 pm
Thanks for responding that the boat under discussion is a 2005 17-foot Montauk. I presume it is a 170 MONTAUK model. If that is not true, please reply to correct.
Still unanswered are my other questions, which I repeat:
--what is the boat speed in statute miles-per-hour at maximum throttle?
Postby biggiefl » Tue Jun 23, 2020 12:23 pm
Since this was a fresh repower, are you getting WOT at the engine?
An error on throttle or shift linkage could be the problem. But I would leave the remedy to whomever installed the engine.
