On a 1986 FRONTIER 25 there are twin Evinrude E-TEC 150-HP engines.
At 4,100-RPM engine speed the boat speed is 34-MPH.
At full throttle the engines accelerate to 5,400-RPM and the boat speed is 48-MPH.
The propellers have 17-pitch.
I don't have enough time yet for data on fuel burn at cruise. The boat has logged about 64-miles.
The route was depart Homer, pass Seldovia, on to Tutka Bay, and back to Homer.
ASIDE: I had a problem with one vapor separating tank at the fitting where the cooling [water] tube enters the [VST] housing. The O-ring seals are important to maintain. If they leak the VST will pull [in] air and water [to mix with the fuel]. [If that occurs after] the engine stalls under load, to restart will be hard.
1986 Frontier 25 Twin 150-HP
Re: 1986 Frontier 25 Twin 150-HP
That you get 48-MPH with 17-pitch propellers is quite amazing at the engine speed of only 5,400-RPM.
quickenberger
Boat speed over ground was 34.4-MPH at 4,100-Rpm
[Deleted image of tachometers and GPS receiver. Your word is your bond, no pictures necessary—Moderator]
My amazement was over the boat speed of 48-MPH at 5,400-RPM.
Assuming the gear ratio of the engines is 1.85, a 17-pitch propeller at 5,400-RPM engine speed cannot reach 48-MPH. The engine speed or the boat speed have to be wrong. Perhaps there was a strong current assisting the boat or the tachometers are off.
My engine has the same gear ratio and a 17-pitch propeller. At 5,700-RPM the boat speed will only be about 42 to 43-MPH. There is no way the boat could be driven by a 17-pitch propeller to 48-MPH with the engine turning only 5,400-RPM.
If the modern E-TEC engines are networked to a multi-function display their engine speed can be read very accurately.
The boat may be reaching 48-MPH speed over ground, but the engine speed is very likely faster than 5,400-RPM to accomplish this. Or, the data was taken while the boat speed was being increased by a very strong current.
quickenberger
Current was probably around 2-3 mph. The tachometers appear correct and are a plug and play style hooked up to the main wire harnesses. When I'm out again this weekend I'll get a picture of the tachs and the fishfinder with the speed its showing. Does the boat speed of 34 mph and the engine speed of 4100 RPM correlate?
Yes but usually with 19" pitch props.
