2005 180 Dauntless Re-power
tlsch377
Postby tlsch377 » Mon Jul 27, 2020 1:29 pm
I have a 2005 180 Dauntless with a 2003 Mercury 135 OptiMax, a counter rotating model. A previous owner did a re-power, when and for what reason, I do not know. The gauges are the smart gauges [possibly means Mercury SmartCraft gauges].
I may re-power, and I am considering a Suzuki DF140 or 150.
[Give me advice on re-powering.]
Money is always a consideration.
I suppose I will need new gauges.
Is [re-powering with another Mercury engine] better [than re-powering with another brand engine]?
Will the current [SmartCraft] gauges work [with a non-Mercury engine]?
Re: repower 2005 180 Daultless
Postby Phil T » Mon Jul 27, 2020 2:01 pm
As of a few years ago most outboard engines moved away from analog gauges. Some engines are rigged [with electronic shift and throttle (EST) remote controls].
My point: any money saved by recycling rigging has been diminished. Many engines support engine data being displayed on GPS/Chartplotter/Monitors.
Masbama
Postby Masbama » Mon Jul 27, 2020 5:16 pm
My previous boat was a 1999 Dauntless 18 powered by a two stroke, carbureted, 150hp Evinrude.
I would strongly recommend a 150hp engine. Mercury makes the lightest 150 four stroke, in case stern weight is a factor.
Re: 2005 180 Dauntless Re-power
Postby jimh » Mon Jul 27, 2020 7:14 pm
Mercury is the only modern engine that does not use NMEA-2000 instrumentation. Mercury uses a proprietary non-compatible system called SmartCraft. From you narrative that mentions “smart” gauges, I infer you have SmartCraft gauges. They won’t be useful on any outboard engine other than a Mercury.
