PolarView: Connecting AIS Receiver via USB
Postby jimh » Sat Jan 28, 2017 8:39 am
I have been using a USB connection to an AIS receiver for the application POLARVIEW NS for many years under MacOS. Below is a screen shot of the port configuration:
In order to make a connection to an AIS USB port, you first have to discover the device name. To find the device name of your AIS USB port, use a terminal window. Enter the command
ls /dev/cu*
--or--
ls /dev/tty*
This will list all devices. To see the data from a serial connection to the AIS device, enter the command
screen /dev/cu.yourDeviceNameHere 38400
For MacOS users it may be helpful to have a handy terminal available. An AppleScript I wrote invokes a terminal window. Here is the text of an AppleScript:
Code: Select all
set baudList to {1200, 2400, 4800, 4800, 9600, 19200, 38400, 57600, 115200, 230400}
set baudRate to (choose from list baudList default items {9600})
tell application "Terminal"
   set serialDevices to (do shell script "ls /dev/cu*")
   set theDeviceList to (paragraphs of serialDevices) as list
   set theDevice to (choose from list theDeviceList)
   do script "screen " & theDevice & " " & baudRate
   set number of rows of window 1 to 24
   set number of columns of window 1 to 80
   set background color of window 1 to "black"
   set normal text color of window 1 to "green"
   set custom title of window 1 to "SerialOut"
   display dialog "To quit your terminal session type control-A then control-backslash "
end tell
Open the Script Editor and paste this text into the editor. Then hit the COMPILE button (the hammer icon). Then SAVE the script.
