My 1998 classic Montauk (Alert 17) has (and came with) an old black-and-white large screen Lowrance SONAR. I'm away from my boat right now, so I can't say which model, but it uses the gray connectors that attach to the back, one for the transducer, one for the paddle wheel speed sensor.
I am perfectly happy with this setup except that the screen has developed lines of missing pixels—more of an irritant than anything else. I see that eBay is flooded with older Lowrance SONARS, some of which may use the same gray connectors. If I could replace mine with one of the same, or maybe even a newer model that still uses the same gray connector format, I'd be thrilled. Is there a source that summarizes which Lowrance SONARS might be compatible with my gray-connector sensor suite?
--Peter
Old Lowrance Gray Connector Compatible Devices
pcrussell50
Re: Old Lowrance Gray Connector Compatible Devices
Peter,
This link may provide the answer to your question:
https://www.lowrance.com/help-and-suppo ... Id=002-437
Lowrance has color coded its connectors, so perhaps Help and Support can answer your question if this page does not.
Ken
Ken
1985 Newport 17
2018 Yamaha F70LA
2017 LoadRite 5S-172200
2018 Yamaha F70LA
pcrussell50
That is a very great help, thank you. Who knew that Lowrance would keep such a list?
-Peter
-Peter
