Boat: Hull never painted, cockpit has been painted with Awlgrip by previous owner. Teak varnished with Interlux Sikkens. Garmin 545s with depth sounder. Standard Horizon VHF w/external speaker. AM/FM Stereo. Reversible leaning post seat. Cooler with seat cushions fore of console. Original BW front vee cushions. Wm. J. Mills set - dodger with boot, sun top/bimini with boot, stainless bows, full mooring cover all appx. 10 years old in like new condition. SeaStar Hydraulic Steering, swim platform with boarding ladder, life jackets, lines, fenders, fire extinguisher, running lights/anchor light, electric horn. Fuel tank replaced by previous owner – pics and drawing/design of tank available.
Motor: Purchased new for this boat 2 previous owners ago. Serviced 5/2021 by Boatworks of South Windsor, CT including lower unit seals (preventative), water pump kit, plugs, lower unit grease change, overall check-up, no recommendations for any additional work needed. Stainless prop rebuilt with less than 100 hours use since rebuild, spare aluminum prop, combination start/deep cycle battery new 2020. Engine starts, idles and runs well.
Trailer: Purchased new for this boat by present owner with all options – hydraulic disc brakes, LED light package, bunks setup for 18’ Boston Whaler Outrage, spare tire holder with spare tire and spare hub, radial tires, spare tire cover, side loading assist poles with PVC extensions. Bearings replaced/repacked May 2021 by Boatworks of South Windsor, CT.
This boat has been well cared for by previous and present owners. The motor is very strong. The boat is located in Connecticut and is ready to use. $18,500. ranjr13@att.net or 860-638-8082.
