On my 2005 270 OUTRAGE with an AIRMAR SONAR through-hull transducer model B744vl I found a leak, occurring mostly through anti-rotation bolt hole. I removed the transducer, expecting to find that it was installed at the location of a putty box in the hull. Instead, I was disappointed at the very poor installation [apparently not using a putty box to surround the large hole through the laminates and foam].
- Fig. 1. No caption has been provided to explain what is being illustrated.
- 1E70A231-C5A6-4670-9BD2-7E21CE4F6ED8.jpeg (29.89 KiB) Viewed 3086 times
- Fig. 2. No caption has been provided to explain what is being illustrated.
- BB911EAB-F339-4308-B423-153C4EAE1C7B.jpeg (19.96 KiB) Viewed 3086 times
- Fig. 3. No caption has been provided to explain what is being illustrated.
- 115BA196-E2A6-4D93-8C7F-B4AC55F34C0F.jpeg (25.02 KiB) Viewed 3086 times
I am planning to install a pair of RV220 SONAR transducers used with [a device identified as an] AXIOM [apparently a model name for a SONAR]; this will eliminate RAYMARINE-brand transom-mounted transducers.
After seeing [the lack of a putty box provided in the Unibond hull], I am now not sure where to go from here.
[Two options for how to proceed are presented;}
- fill transducer hole eliminating the B744vl and worry about [the next step] over the winter months
- re-install B744vl properly and later remove and fill-in the hole
Give me comments and perhaps guidance on y best course of action.
ASIDE: There's definitely some waterlogged foam. I am of the opinoin that the only Boston Whaler boats with dry foam are Boston Whaler boats in a dealer showroom.
