1985 MONTAUK 17 Bow Railing Base Repair
Teleni
Postby Teleni » Mon Feb 13, 2023 4:09 pm
The base area where the center [stanchion] of the bow railing is mounted on my 1985 17' Montauk [has been damaged]. The two screw fasteners that hold the [stanchion] are loose. I removed the [stanchion], and I noticed that there is an [embedded] aluminum plate with two holes laminated [into the hull] there.
Fig. 1. Montauk bow railing base damage
Give me advice on how to repair the base for the railing stanchion.
Any advice and suggestions will be greatly appreciated.
Freddy
Re: 1985 MONTAUK 17 Bow Railing Base Repair
Postby Phil T » Mon Feb 13, 2023 5:00 pm
  • Over drill the holes.
  • Fill the holes with Locktite Marine Epoxy.
  • Drill for the screws and reinstall the railing base then the vertical rail.
