I have a 2007 150 Montauk and I'd like to add a bimini. Does anyone know the OEM supplier? I though it was Great Lakes, but they're saying they only started with the 2008 model. I believe the hull is identical for both 2007 and 2008 model years, so I'm assuming it would work fine.
I know about Mills, but would like to keep costs down. Carver also makes a decent option, but I'm not crazy about the plastic mounting hardware that comes with the Carver, and would prefer stainless mounts with quick release for the support rod so I can stow the top with a mooring cover.
If anyone has any advice, I would appreciate it.
2007 150 Montauk OEM Bimini Supplier
Re: 2007 150 Montauk OEM Bimini Supplier
You can purchase stainless steel mounting hardware with your Carver top if you purchase through one of their vendors.
I did this exact thing with my Outrage 17.
https://www.boatcoversdirect.com/products/bimini_tops/BOSTON_WHALER_75/170_MONTAUK_O-B_W-_BOW_RAIL_W-_SIDE_RAILS_2121/23/A5475UB/8/
Note the "SELECT FITTINGS" drop down list just above the ADD TO CART. Select Stainless Steel (+$99)
Track slides and struts are also available (and recommended)
