Lack of dimensions or scale on drawing for 210 MONTAUK reinforcement area
boatsmith
Postby boatsmith » Thu May 14, 2026 10:09 am
In [an unspecified model year] 210 MONTAUK owner’s manual, a drawing [of the hull] shows reinforced areas as approximate locations, and there is no scale.
Q1: using the drawing referenced above, how can the reinforcement areas be located precisely?
Re: Lack of dimensions or scale on drawing for 210 MONTAUK reinforcement area
Postby jimh » Thu May 14, 2026 6:31 pm
If the unseen drawing lacks dimension lines, the location of the reinforced areas of the hull will not be able to be precisely located using that drawing.
Reinforced areas of the hull can be located by tapping the hull and listening for a change in the sound.
There may be (and probably will be) better drawings available from Boston Whaler.
See the pinned article for advice on how to find drawings of recent production models on the WHALER.COM website.
How to locate drawings on the WHALER.COM website
https://continuouswave.com/forum/viewto ... f=4&t=9897
