Modern GNSS Receiver with USB Interface: the YIC GU-605GGBL5-USB
Postby jimh » Fri Oct 09, 2026 9:54 am
Many years ago, c.2011, I purchased a GPS receiver with a USB interface, a GlobalSat BU-353. The price was about $35, and the receiver only worked with the U.S. Air Force NAVSTAR GPS constellation. But it worked well and is still working 15-years later.
The state of the art in GNSS receivers has advanced considerably in those 15 years. In October 2026 I bought a modern GNSS receiver with multi-constellation capabilities (GPS, GALILEO, GLONASS, and BEIDOU) and multi-signal (L1/L5 and E1/E5), with 200 channels (correlators), amazing sensitivity, 10-Hz update, and a USB interface, and for only $43: the YIC model GU-605GGBL5-USB. This device has astonished me with its performance.
The receiver was delivered just yesterday afternoon. Connecting it to a USB port for my Apple Mac Mini M4 computer took a bit of configuration, as a device driver had to be downloaded and installed. (More on this later.) However, on being connected and powered on the USB bus, and just sitting on the window sill of a south-facing second-storey window, the USB 115,000-BPS connection began reporting a position solution in a matter of a few seconds.
My initial curiosity was to see what constellations and how many satellites were in view, and also to see if the L5 and E5 signals were being received. The results were mind-blowing. Here is a sample of the NMEA-0183 data coming from the receiver that reports "satellites in view":
    $GPGSV,3,1,11,03,47,253,35,04,39,310,37,09,00,000,22,16,51,190,42,1*68
    $GPGSV,3,2,11,26,77,107,25,28,33,070,31,29,16,055,34,31,60,052,34,1*60
    $GPGSV,3,3,11,32,11,128,34,44,00,000,41,46,00,000,33,,,,,1*5E
    $GPGSV,2,1,08,03,47,253,26,04,39,310,41,16,51,190,00,26,77,107,32,8*67
    $GPGSV,2,2,08,28,33,070,35,29,16,055,00,31,60,052,00,32,11,128,25,8*6C
    $BDGSV,3,1,09,14,72,224,38,21,55,170,30,22,07,150,16,24,19,237,38,1*70
    $BDGSV,3,2,09,26,66,244,36,33,11,320,18,36,00,000,00,39,51,052,41,1*7F
    $BDGSV,3,3,09,42,62,292,35,,,,,,,,,,,,,1*41
    $BDGSV,2,1,07,21,55,170,27,22,07,150,20,24,19,237,31,26,66,244,27,3*7B
    $BDGSV,2,2,07,33,11,320,26,39,51,052,33,42,62,292,40,,,,,3*43
    $BDGSV,2,1,08,14,72,224,00,21,55,170,00,22,07,150,00,24,19,237,00,5*70
    $BDGSV,2,2,08,26,66,244,00,33,11,320,00,39,51,052,00,42,62,292,00,5*7C
    $BDGSV,2,1,08,21,55,170,29,22,07,150,16,24,19,237,35,26,66,244,33,2*7F
    $BDGSV,2,2,08,33,11,320,11,36,00,000,00,39,51,052,39,42,62,292,13,2*70
    $GLGSV,2,1,08,78,38,037,36,70,26,325,33,80,27,227,32,79,81,278,28,1*7A
    $GLGSV,2,2,08,69,78,330,39,68,46,144,21,67,00,000,00,87,02,029,00,1*73
    $GAGSV,3,1,09,07,34,113,37,10,00,000,00,19,37,306,28,21,33,191,32,7*76
    $GAGSV,3,2,09,27,66,112,33,28,00,000,00,29,83,030,40,30,31,048,39,7*76
    $GAGSV,3,3,09,33,03,242,14,,,,,,,,,,,,,7*48
    $GAGSV,2,1,07,07,34,113,28,19,37,306,25,21,33,191,32,27,66,112,26,1*7E
    $GAGSV,2,2,07,29,83,030,32,30,31,048,26,33,03,242,11,,,,,1*4E
As can be seen in the above, the NMEA sentence GSV (satellites in view) is now showing four different constellations. The prefix $G* and $BD identifies the four constellations, as follows:
$GPGSV = U.S.A. GPS
$GLGSV = Russian GLONASS
$GAGSV = European GALILEO
$BDGSV = China BEIDOU
To parse the NMEA-0183 sentences I asked GROK.com to assist. Grok reported as follows:
Parsed satellites in view from the supplied GSV sentences
GPS (GP) – system ID / signal ID mostly 1 or 8
Total reported in view: up to 11
PRN Elev(°) Azim(°) SNR (dB-Hz) Notes / signal
03 47 253 35 / 26 Signal 1 & 8
04 39 310 37 / 41 Signal 1 & 8
09 00 00 22 Signal 1
16 51 190 42 / 00 Signal 1 & 8
26 77 107 25 / 32 Signal 1 & 8
28 33 70 31 / 35 Signal 1 & 8
29 16 55 34 / 00 Signal 1 & 8
31 60 52 34 / 00 Signal 1 & 8
32 11 128 34 / 25 Signal 1 & 8
44 00 00 41 Signal 1 (SBAS)
46 00 00 33 Signal 1 (SBAS)
BeiDou (BD)
Total reported in view: up to 9
14 72 224 38 / 00 Various
21 55 170 30 / 27 / 00 / 29 Multiple sets
22 07 150 16 / 20 / 00 / 16 Multiple sets
24 19 237 38 / 31 / 00 / 35 Multiple sets
26 66 244 36 / 27 / 00 / 33 Multiple sets
33 11 320 18 / 26 / 00 / 11 Multiple sets
36 0 0 00
39 51 52 41 / 33 / 00 / 39 Multiple sets
42 62 292 35 / 40 / 00 / 13 Multiple sets
GLONASS (GL)
78 38 37 36
70 26 325 33
80 27 227 32
79 81 278 28
69 78 330 39
68 46 144 21
67 0 0 00
87 2 29 00
GALILEO (GA)
07 34 113 37 / 28
10 0 0 00
19 37 306 28 / 25
21 33 191 32 / 32
27 66 112 33 / 26
28 0 0 00
29 83 30 40 / 32
30 31 48 39 / 26
33 3 242 14 / 11
For even a better indicator of how many satellites where available in the four constellations, I asked Grok to produce a sky view polar plot. It took a rather long 40-seconds to produce the graphic:
Fig. 1. Polar plot of satellites in view using the modern YIC GNSS L1/L5 USB receiver. This instance is with the receiver indoors and sitting on a south-facing window sill.
There were a possible 37 satellites in view. There were good signals (elevation > 0-degrees and non-zero SNR reported) from 34 satellites. The sky polar plot only shows 20, which perhaps is just a limitation of the AI graphic generator. There are some errors; for example, there is no GPS PRN "33" listed, but the plot shows a GPS satellite "G33". I think GROK had a few glitches generating the polar plot of satellites in view.
The data shown are just from a random moment in time at a random location in southern Michigan with an indoor antenna location. For me, the results are just amazing, compared with what a GPS-only c.2010 receiver would be able to produce. Both the L1 and L5 civil signals on GPS were received, and both the E1 and E5 signals on GALILEO were received. All four GNSS constellations were received. All that for $43.
Re: Modern GNSS Receiver with USB Interface: the YIC GU-605GGBL5-USB
Postby jimh » Fri Oct 09, 2026 11:03 am
I sourced the YIC GU-605GGBL5-USB from DigiKey at a price of $42.96. The total cost including tax ($2.48) and shipping ($8.49) was $54.03.
The DigiKey part number is 3155-GU-605GGBL5-USB-ND.
The manufacturer part number is GU-605GGBL5-USB.
Postby jimh » Fri Oct 09, 2026 11:14 am
To be able to see the YIC receiver on the USB bus on my Apple Mac Mini M4 (running MacOS Sequoia 15.7.4), I had to install a special driver. Without the special USB driver the YIC receiver was not detected on the USB bus.
Information about where to find the necessary driver and how to install was found at
https://community.gpswebshop.com/tech-s ... for-macos/
Depending on the version of MacOS, the graphic showing where to find the "Driver Extensions" may not be as shown. You can find that resource by entering "Driver extension" in the search box at System Settings ---> General.
The DEFAULT baud speed from the receiver is 115,200-bps.
You can test for proper operation of the receiver with MacOS by using the TERMINAL app.
In a terminal window enter:
    cd /dev
    ls cu*
You should see the YIC receiver listed as
    cu.PL2303G-USBtoUART1230
In the terminal window enter
    screen /dev/cu.PL2303G-USBtoUART1230 115200
You should see a stream of NMEA-0183 data in a newly opened terminal data window.
Use with OpenCPN
I also tested the YIC multi-constellation USB receiver with the OpenCPN application. It works well with the device, but the extension or plug-in to add a graphic for satellites-in-view is not able to handle the complex reporting of multiple constellations.
Satellites in view by constellation
The GPS constellation has the most satellites in view (11), but that is because the receiver is counting two space-based-augmentation-system (SBAS) satellites, provided by the FAA’s Wide Area Augmentation System WAAS, identified by PRNs 44 and 46 due to NMEA coding (which cannot handle higher numbers). NMEA reports the WAAS PRNs using a translation of NMEA PRN = PRN - 87, so the actual PRNs used for WAAS in this case are 131 and 133. Those WAAS signals are originating from geo-stationary satellites on the equator at longitudes 117° West (Eutelsat 117 West B) and 129° West (SES-15).
Absent those two geo-stationary orbit signals, GPS, GALILEO and BEIDOU all have 9 satellites in view; GLONASS has 8.
For more about SBAS PRN number allocation, see
A Fifth WAAS Satellite Coming
https://continuouswave.com/forum/viewtopic.php?t=2195
and also
WAAS Satellite Changes
Postby jimh » Mon Oct 19, 2026 10:39 am
Figure 1 is a screen capture of a polar plot of satellites in view at my location on a recent date. The YIC modern GNSS receiver is tracking 38-satellites. The position fix accuracy for 50-percent CEP is 1-cm or about 1/2-inch.
Fig. 1. Satellites in View polar plot using YIC USB GNSS receiver indoors, with the antenna on a south facing seccond-storey window.
