1978 Classic 15-footer Repair
Hi. I am new to the forum and would like to share pictures and information on ongoing work that is being done.
Starting off with some pictures taken Oct. 2016, just before i bought the classic. I will use the boat bringing the kids out in the fjord, as well as for fly fishing after bass and seatrout.
- Bw classic
- IMG_20161013_135154-800x450.jpg (115.78 KiB) Viewed 11581 times
- Bw classic
- IMG_20161013_135429-800x450.jpg (90.1 KiB) Viewed 11581 times
Re: 1978 Classic 15-footer Repair
That whaler looks to be in good shape for the age. What do you plan on doing to it?
The old wood was not much to look at, so I have striped the boat clean and then sanded the wood. I need to aply some stain and varnish.
Theres a few more detailes that i will look into, some safety, lights, vhf, and chrome details.
There has been only one owner before me.
I have the exact same boat and it was in that identical condition when I bought it. I spent about 10-12 hours total refinishing the mahogany (removed it to do a thorough job). Looks to be a Mercury on the back. I picked up a 2004 Mercury 40 in pristine condition. Couldn't be happier: she pushes 35 mph with 2 fairly hefty adults aboard. Sips gas. All I have left to do now is buff out all her battle scars, and polish her up... Good luck with yours - it's the best Whaler I've had and I've had 9 of them...
Thx boys,
Its an 40 hp Evinrude 2008, and I am using a 40 liter fuel tank. The cost of fuel is 2 USD pr liter where i live. A more economical engine would be a nice upgrade. Anyway, what size of prop did you use on your merc.
Without wood
- Ribbed
- IMG_20170410_145402-480x853.jpg (120.99 KiB) Viewed 11552 times
The console is worn out.
- 1978 Boston whaler 15 Consol
- IMG_20170410_153803-450x800.jpg (119.11 KiB) Viewed 11549 times
- IMG_20170410_153821-800x450.jpg (169.4 KiB) Viewed 11549 times
- IMG_20170410_153755-800x450.jpg (143.78 KiB) Viewed 11549 times
Some more pictures off sanded finishes. Last finish is done with 240.
- 1978 Boston whaler 15 sanded
- IMG_20170410_131817-480x853.jpg (106.68 KiB) Viewed 11549 times
- IMG_20170410_082201-480x853.jpg (125.13 KiB) Viewed 11549 times
- IMG_20170409_125540-853x480.jpg (87.62 KiB) Viewed 11549 times
After reading the forum i noticed that GRANT made a six-spoke steering wheel in c.1978. What is funny is that [my boat steering wheel has] only five spokes which lets me think that the boat was sold with incorrect info. What do you think?
On my 1976 SPORT 15 the OEM steering wheel was not a stainless steel wheel with six spokes. It was a black plastic wheel with two spokes. The helm was mounted in about the same location, but the helm was not mounted with the axis of the wheel rotation vertical. The helm was angled toward the helmsman at about a 30-degree angle. There was no retangular metal escutcheon plate at the base of the helm as seen on the boat under discussion.
These three variances suggest that the steering wheel and helm seen above are not the OEM components.
The image below shows my 1976 SPORT 15 helm:
Also compare several other views seen in
http://continuouswave.com/whaler/reference/15/models.html
Thx Jimh.
I will keep the wheel, but a new hydraulic helm at 30-degrees, preferable chrome, would be fine; but black will work just as fine. The tilting helms out there costs a lot. A fixed-30-degree would work just fine. Let me know if you know about any manufacturers.
For the record I am a Norwegian, and the boat will enjoy me in the inner parts of the Oslo Fjord.
59°52'00.4"N 10°36'13.4"E
https://goo.gl/maps/vXBMyfQ8xeA2
My 40 HP Mercury has a 14 pitch x 10 or 10-3/8 - not sure which is the recommended. It's perfect for my boat - and I've had 15's with 70 Yamahas (WAY too zippy for me)..
Re helm choices: I am not sure about availability in Norway, but in North America the Teleflex mechanical steering helms have been very popular and were probably the OEM choice for Boston Whaler. The name TELEFLEX is no longer associated with marine products, and a new name, SeaStar Solutions is being used. Compare at
http://www.seastarsolutions.com/product ... -steering/
See http://continuouswave.com/forum/viewtopic.php?f=4&t=2044 for more details about the change in name to SeaStar Solutions.
Yes indeed - no reason at all to put hydraulic steering on a 15! The no feedback cable system works great - steers just as easily, is much less expensive, and requires a lot less maintenance! As you will be in salt water, I would highly recommend installing a steersman nut to keep things working smoothly - check it out here: http://www.steersman.com/html/whatitdoes.html
Send along some pictures once you're out on the water!
Flymo
Flymo
That is sweet.
Iam about to apply some varnish on the sanded wood. Can i be sure that the boat came with mahogney originaly?
Can you explain what you mean with "WAY too zippy."skred wrote:My 40 HP Mercury has a 14 pitch x 10 or 10-3/8 - not sure which is the recommended. It's perfect for my boat - and I've had 15's with 70 Yamahas (WAY too zippy for me)..
Do we have drawings of these rodholders?
- rod holders
- 844.jpg (35.22 KiB) Viewed 11448 times
Why do you want a drawing of a rod holder that won't fit a SPORT 15?
"WAY too zippy" probably means there was excessive propulsion power and acceleration.
I don't know of any other classic rod holders made off wood. If I [were] to use them, i would have had them made to the boat. To get the finishing product to resemble a Boston Whaler product I could have use of these drawings.
Years back, I had a 1984 15 Sport Center Console with a 70 Yamaha on it. When my GPS hit 42 mph, and the boat started "chine walking", I decided I really didn't need that much speed - especially since I was primarily fishing Lake Michigan. The wave swell spacing and height on a lot of days really wouldn't allow that kind of speed. With my present 15 Sport, the 40 EFI Mercury with the described prop is just perfect for me. I don't do Lake Michigan much any more, and here on Golden Lake in Oconomowoc, WI, it's a perfect fit with a top speed of 34 mph. And - it sips gas!
Re drawings: all the drawings that are hosted here at listed at
http://continuouswave.com/whaler/refere ... wings.html
The drawing index used to list many more drawings that individual people were hosting on their own websites, but in the 14 years since that article was first published, many of the links to drawings became dead links because those people moved the drawings to some new location that is not openly available, or people wanted to sell the drawings, or people abandoned their websites entirely. I removed the dead links. Now there are fewer drawings.
Boston Whaler has been willing to email to individuals just about any drawing they have available, so to some extent having a small subset of the probably thousands of drawings available from Boston Whaler by email listed here for download is not quite as important as it would be if Boston Whaler were not so customer-oriented and willing to email out just about any drawing they have.
Re rod holders: the rod holders shown (above) are for OUTRAGE type hulls. The upper part of the rod holder fits under the overlapping gunwales of the cockpit. The relief in the upper edge creates a path for cables to run under the gunwales. I don't have a drawing of these. I don't know where you can find a drawing on-line. I don't know if Boston Whaler has one. The easiest way to duplicate those rod holders would be to use an old one as a pattern.
The boat has done its jobb, Seabass, Seatrout, and more. Iw had a very good sommer sow fare due to this boat. It turned out ok after all.
Hope you all have had a nice summer.
Br Rags
Br Rags
- Boston Whaler 15
- 20170731_071440.jpg (124.23 KiB) Viewed 10845 times
- Boston Whaler 15
- 20170731_071342.jpg (146.16 KiB) Viewed 10845 times
