Trailer Rigging for 1998 OUTRAGE 17 II
MountainWhaler
Postby MountainWhaler » Sun Dec 14, 2025 3:47 pm
Q1: what are the dimensions of a 1998 OUTRAGE 17 II as illustrated in Figure 1 below?
Fig. 1. Drawing supplied by trailer dealer that is much too low resolution to be of any use as a graphic.
I have purchased a trailer for a 1998 OUTRAGE 17 II boat. The trailer dealer has requested some dimensions of my boat so they can set up the bunks and bow roller before they deliver it to me.
Most important are [three simple measurements which can be described as]:
  • A, the distance from the transom to the bow eye;
  • F, the width between the inner chines; and
  • G, the width between the outer chines.
I would really appreciate it if anyone out there has an OUTRAGE 17 II, and would be able to take a few measurements.
Re: Trailer Rigging for 1998 OUTRAGE 17 II
Postby jimh » Sun Dec 28, 2025 3:54 pm
One problem that may have limited your replies is the use of an illustration of such low resolution that it was no longer of much help in soliciting the measurements needed. The image you used was only 148-pixels wide. Also the image contains mostly unnecessary white space above and below the actual drawing. The file size was only 7.4-Kbytes.
The forum is pleased to host any illustration up to 900 x 900 pixels and up to 250-Kbytes. If you have a higher resolution drawing of the hull measurements needed by the dealer, please post that drawing.
The approach of the Christmas holidays have also likely reduced the normal forum participation.
Also, for many northern boaters, our boats are tucked away in storage barns and not easily accessed at this time of the year.
Postby Phil T » Fri Jan 09, 2026 12:44 pm
Typically owners purchasing a new trailer will select a model that has the appropriate capacity rating and features necessary and desired.
When the trailer has arrived from the manufacturer, the selling dealer typically preps the trailer, installing the separated wheels, winch post, and other components that have been removed for ease of shipping.
As for boat fitment, the bunks are initially set high and about 2-feet off the center line to start. The boat is lowered onto the trailer and its position assessed. The technician will take note of the keel position in relation to the frame cross members and the transom position in relation to the aft cross member.
Adjustments are made so that the boat is as low as practical.
The bunks are not resting on the chines.
The winch post is adjusted with the boat on the trailer.
There is no precise predetermined location for the bow roller, but it should be resting on top of the bow eye.
Postby jimh » Sat Jan 10, 2026 12:14 pm
Phil T--your advice is excellent. If the thread originator ever gets back to read the replies in this thread, he will be enlightened by your comments.
Also, to add a bit more to what Phil has said, the general hull shape of a Boston Whaler boat does not have much hull flare outward above the chine line. Generally the hull sides of a Boston Whaler boat above the water line are just about vertical with little to no increase in beam as the height above the waterline increase.
As a result, the hull width at the chine line is typically what determines how low onto the trailer the boat can be situated, unless the hull's beam is so narrow it can fit between the fenders of the trailer.
If the boat can't fit between the trailer fenders, then that interference is probably going to determine how far the boat can be lowered to be carried on the trailer. If the trailer is a bunk design and the boat is loaded very level onto the trailer, you only need a vertical clearance of an inch or two between the fenders and hull.
Generally the trailer width is going to be limited to 102-inches so that it conforms to most state laws about exemption from "over-wide" classification. Depending on the design of the fenders, they may be 8-inches wide or more. If we consider the trailer width was maximized to the 102-inch limit, then subtracting 16-inches (or more) will give an estimate for how much room remains between the fender, which would be 86-inches or 7-feet 2-inches. The specified beam of an OUTRAGE 17 II is 7-feet 0-inches, so it might be possible to fit between the fenders, but the clearance would be very small, perhaps just 1 to 2-inches.
On my own trailer, I have lowered the boat so that the chine line clears the fenders by about 1.5-inches, and I have never had a problem with the boat hull has coming in contact with the trailer fenders during loading (or launching).
There are several reasons why carrying the boat low on the trailer is better than higher. The lower the boat sits on the trailer:
  1. the easier it will be to float off the trailer during launching;
  2. the easier it will be to float onto the trailer during loading;
  3. the lower the boat the lower the center of gravity of the boat-trailer rig when on the road, leading to more stability when towing on the highway; and
  4. the easier to climb into or climb out of the boat when it is on the trailer.
Reasons 1 and 2 will be important because they may keep your towing vehicle from having to back down a launch ramp and get the rear axle into the water to launch or load the boat.
Reason 3 has no downside, except if the hull is so low on the trailer that the engine must be tilted up to avoid striking the ramp pavement during launching, loading, and when traveling on roads where there is sharp transition to an incline or decline.
Reason 4 is actually quite important, as boat that is stored on its trailer during boating season is going to be climbed onto and climbed off of many, many times. With my trailer, I get on or off the by stepping from the fenders and then over the gunwales, and similarly for getting off the boat.
Postby jimh » Sat Jan 10, 2026 12:34 pm
Regarding trailer set up and rigging, there is an excellent article on that topic in the REFERENCE section, see
Trailer Rigging for Boston Whaler Boats
https://continuouswave.com/whaler/reference/trailering/trailer.html
In addition to vertical height on the trailer, the fore-and-aft position of the boat on the trailer is also important. In my opinion, you want the transom of the boat to be located as far back on the trailer as possible but still have the transom supported by the trailer bunks. Then you adjust the winch position to be optimum for that orientation.
Once you have set up the boat on the trailer, the next adjustment will be to consider the tongue weight. The tongue weight should be optimize to be at least 5-percent of the total towed weight, and never more than the permitted maximum weight of the hitch system, which includes the trailer's coupler, the hitch ball, the drawbar, and the hitch on the vehicle.
In addition to the ratings of the hitch system, you also need to look carefully at the loading onto the tow vehicle axles and tires. Tongue weigh is transferred mainly onto the rear axle of the towing vehicle, and it also tends to reduce the weight on the steering axle of the vehicle.
The only way to assess the weight distribution of the combination of the boat-trailer attached to the tow vehicle, is to take the rig to a certified scale and get two weighings, one with the trailer attached and one without the trailer.
For details about using a certified scale to find weight distribution, see this 18-year-old discussion on that exact topic:
Boat Weight From Certified Scale
https://continuouswave.com/ubb/Forum1/HTML/016667.html
If you discover the tongue weight is improper, you can adjust the tongue weight by moving the trailer axles slightly. Rather than move the trailer axles and the re-weigh to see if you got it right, you can pre-compute the distance needed using the method described in an article in the REFERENCE section. See
Trailer Hitch Loads
Considerations and Calculations
by Jerry Townsend
MountainWhaler
Postby MountainWhaler » Mon May 18, 2026 11:54 am
Thank [all] for taking the time to give such detailed replies. I’m just now [four months late] seeing these.
FOLLOW UP
I was able to get somebody to measure the boat in person and give those dimensions to the trailer dealership who set the bunks up. After a lot of sweating, swearing and elbow grease we managed to get the boat from where it was sitting on pallets on the ground up onto the trailer. To my great relief the boat sits on the trailer perfectly.
I purchased the trailer from Enterprise Marine in Central Florida, and recommend them highly. They were great to deal with.
A relative of mine was kind enough to tow the boat from Florida to Louisiana. In about two weeks, I’ll drive down to Louisiana and bring back the boat to Colorado.
Then I can get the 1998 OUTRAGE 17 II cleaned up and put on our local lake.
