Q1a: what should be the weight of a 1989 OUTRAGE 20?
Q1b: is 220-lbs in water-saturated foam a lot or a little?
Q2a: can a 1989 OUTRAGE 20 be left for the winter [with a cover] and allowed to dry until April 2027?
Q2: should I begin the restoration of a 1989 OUTRAGE 20 in November 2026 instead of waiting for the boat to dry over winter?
Q3: should I take core samples of the transom prior to ripping apart the transom?
Q4: should I drill holes into the hull at the bottom to allow entrapped water to drain?
Q5: what should I do with the raised "bed" in the bow at the height of the corner seats?
Give my any advice on restoration of a 1989 OUTRAGE 20
I just purchased a 1989 Outrage 20. The boat came with no engine.
After a good cleaning,I was able to pop-out the below-deck fuel tank and remove the bad foam surrounding it.
I started drilling out all of the existing holes to make them bigger to accept pouring epoxy into them to fill, patch, and sand.
I weighed the boat and found it seem to be just around 220-lbs over [some unspecified and unmentioned] weight.
1989 OUTRAGE 20 Restoration
Re: 1989 OUTRAGE 20 Restoration
Posts that ask SEVEN questions can be very awkward. It is better to concentrage on one topic at a time in individual posts.
Accordingly, I will only comment on the expected weight of a 1989 OUTRAGE 20.
The only known weight of the hull of a 1989 OUTRAGE 20 would be the "dry weight" as listed by Boston Whaler in their catalogue for 1989, which I believe was 1,850-lbs.
Cf.: https://continuouswave.com/whaler/refer ... hulls20-22
The "dry weight" of a Boston Whaler boat is just the hull without any options, without any engine rigging, with no fuel in the fuel tank, and no added gear aboard.
Your statement that you measured a hull weight that exceeded some unspecified expected weight by 220-lbs is not particularly useful information, as readers have no idea of what you thought the expected weight should have been nor your allowances for what was aboard the boat when it was weighed, nor in the details of how the boat was weighed, nor of the calibration of the scale used.
Further for a boat that was molded 37-years-old, there is no knowledge of the production tolerance for a particular hull to deviate from the specification value of dry weight. The boat could have been heavier than 1,850-lbs the day it was molded in the factory.
I don't see any urgency to obsess about 220-lbs of variance from your expected outcome. As a general rule, boats always weigh more than you think they do.
I certainly would not begin destructive exploration of the transom and hull bottom on the basis of the weight variance.
luker01 wrote:Q1a: what should be the weight of a 1989 OUTRAGE 20?
Water weighs about 63-lbs per cubic foot. Assuming that foam can hold about 90-percent of its volume with water, we could attribute 0.9 x 63-lbs or 57-lbs of the weight of one cubic foot of water-saturated foam to the water. On that basis if there were 220-lbs of water in the boat, its volume would then be 220-lbs / 57-lbs/1-cubic-foot = 3.8-cubic-feet of saturated foam holding 90-percent water.luker01 wrote:Q1b: is 220-lbs in water-saturated foam a lot or a little?
If you discovered that the foam surrounding the fuel tank held water, you should have removed and weighed a known volume of the foam to discover how much it weighed and thus its density. This would have given you a real-world figure for the weight of water-saturated foam.
Also, the method of construction of a Boston Whaler Unibond hull involves a chemical reaction in the creation of the foam. One of the products of the reaction is production of water. The expulsion of every drop of water from the foam contained in the space between the hull and the liner of a Unibond hull is probably not 100-percent, that is to say, there is probably some water in the foam in the interior space of a Unibond hull on the day it was made.
There is also likely to be some uncured polyester laminating resin in places, too. The uncured resin and entrapped water are often encountered in older Boston Whaler boats, even ones whose care and maintenance has been extraordinarily good.
Please read the FAQ at
Q3: Is there water in a Unibond hull?
Thanks, great info.
I was [assessing the measured scale weight of the boat] against a dry [hull] weight of 1,850-lbs. I agree: 220-lbs is not a lot of weight, but I would like to get the boat as dry as possible before closing up [the boat restoration].
I [may] have identified a couple of very specific areas where water has accumulated.
For the sake of maybe tracking down the source I am going to cut out [something unidentified] and see what [I will be] working with.
I did find two through-hull [drain] holes, the one in the anchor locker and the one [in the cockpit sump on] the starboard side near the stern. that did not have the brass tubes in them. All water was going straight into the foam in those spots.
On November 4, 2026 the hull bottom will be soda blasted [to remove bottom paint]. Then I will have visibility into the condition of the hull bottom.
TexasBoatBuilder
Finding those two drain holes without their brass tubes probably explains a good part of the water in the foam. I hope the soda blasting showed a sound bottom.
I look forward to following the restoration of the 1989 OUTRAGE 20.
