DAUNTLESS v. OUTRAGE Deadrise Angle
Buoy
Postby Buoy » Thu Dec 15, 2016 11:27 pm
Hi all. What is the deadrise angle on [the 2002 180 Dauntless and 2006 190 Outrage]?
The specifications are very similar for both [the 2002 180 Dauntless and 2006 190 Outrage].
Should we expect any significant differences in performance and comfort?
SPECIFICATIONS   180 Dauntless  190 Outrage
Engine 130 Yamaha* 150 Verado
Year 2002 2006
Length 18' 6" 18' 10"
Beam 8' 8'
Draft 12" 12"
Dry Wt 2000 2050
Weight Capacity 2600 2200
Swamp Capacity 4000 4000
Persons Capacity 8 8
Fuel Capacity 60 60
Max HP 150 150
Min HP 125 115
Engine Shaft 25" 25"
Max Engine Wt 510 530
Bridge Clearance 5' 6' 5"
Freeboard 20" 22"
* = two-stroke-power-cycle engine
All feedback is welcome. Thanks.
Re: DAUNTLESS v. OUTRAGE Deadrise Angle
Postby Jefecinco » Fri Dec 16, 2016 9:07 am
The deadrise angles should be available on the Boston Whaler websites.
As to performance, fifty pounds of weight and twenty horsepower shouldn't make much difference. However, you may want to compare the torque figures between the engines. In practical use I've found the 135 Verado to be particularly strong on our 190 Montauk. The acceleration across the RPM band is very impressive with the Verado. The Outrage with the Yamaha engine has, I assume, been repowered. There have been some serious and expensive to correct problems with some Yamaha exhaust systems recently. I recommend you look into that as part of your analysis.
Comfort is difficult to define. The Dauntless hull should be more stable due to less deadrise. The Outrage hull should be a little less bumpy in choppy conditions. For family boating the Dauntless layout (with optional seating) should be more accommodating. The Outrage layout should be better suited for hardcore offshore angling.
In the conditions most of us prefer for boating I doubt you would notice little if any difference in ride quality.
Finally, you should operate both boats before deciding which one more closely meets your requirements.
Postby jimh » Fri Dec 16, 2016 9:12 am
Using the data above for dry boat weight and horsepower, I calculated the lbs/HP ratios as
180 DAUNTLESS = 15.4-lbs/HP
190 OUTRAGE = 13.7-lbs/HP
Since the 190 OUTRAGE has a better (lower) weight-to-horsepower ratio, it should accelerate faster, assuming the hulls are generally similar.
Since the 2002 180 DAUNTLESS has a two-stroke-power-cycle engine while the 2006 190 OUTRAGE has a modern VERADO propulsion system, I would expect that the general user satisfaction with the engine will be greater with the VERADO. The VERADO propulsion system--it's not just an outboard engine any more--should be more fuel efficient (as long as you are not running it at maximum throttle), the control system will be electro-mechanical instead of mechanical, it will have digital instrumentation (although using a proprietary protocol that is not particularly easy to connect to generic displays), and exhaust gas emission, smoke, and soot should be lower.
We are talking about 18-foot boats with generally similar hulls, so I would not expect there to be an astonishing difference in the ride or comfort or seakeeping abilities of the hulls.
As JEFE notes, the layout of the two hulls is probably more influential. But I think both are center consoles. Here is an nice 2002 180 DAUNTLESS with added custom-fitted weather canvas:
See some prior comments about the c.2002 180 DAUNTLESS at
http://continuouswave.com/ubb/Forum8/HTML/001471.html
Here is a comprehensive review of the 2002 180 DAUNTLESS by an owner of ten years:
http://continuouswave.com/ubb/Forum8/HTML/004483.html
And another good discussion of the 180 DAUNTLESS from another long-term owner:
http://continuouswave.com/ubb/Forum8/HTML/002700.html
Postby Phil T » Fri Dec 16, 2016 3:09 pm
The Dauntless is marketed as a lake or near shore vessel versus the Outrage which can handle near and off-shore.
The Boston Whaler website has very limited information for older model boats. While the deadrise of the two models is far from similar, I would contact Customer Service and ask. http://www.bostonwhaler.com/contact-us/.
What do you want to do, under what conditions and where will it be done?
Buoy
Postby Buoy » Sat Dec 17, 2016 12:04 am
Thanks all for your responses. I currently own the 180 Dauntless and am in contract to purchase the 190 Outrage. I just recently started looking at the 190 Outrages thinking that there would be some incremental improvement in performance over the 180 Dauntless. I truly love the styling and layout of the Dauntless but performance in the chop is more important to me than additional seating and storage.
I'll be using those boats for clamming, crabbing, fishing, bringing the dogs swimming, etc. I think the stern platform on the Dauntless makes loading the dogs back onto the boat a bit easier, and hopefully the Outrage's two additional inches of freeboard will help keep the mutts inside the boat :-)
I've never ridden in a 190 Outrage but it appears to be much larger inside than the 180 Dauntless, it looks deeper. They appear to have near equal square footage of cockpit space given the Dauntless's integrated stern bench versus the Outrage's larger console footprint.
I could not find dead-rise stats on the BW site so I called them and fortunately for them they are closed for the remainder of the year. I'll keep searching, thanks again.
Ridge Runner
Postby Ridge Runner » Sat Dec 17, 2016 8:50 am
As you can see in these pictures the 2006 190 Outrage has a deeper and sharper bow entry (Deeper V) that is carried farther aft than the 2002 180 Dauntless. The Outrage will have better sea keeping abilities than the Dauntless. While the Dauntless will have better stability than the Outrage at rest.
2002 180 Dauntless:
2002 Dauntless 2.jpg (32.72 KiB) Viewed 10376 times
2006 190 Outrage:
2006 Outrage.jpg (53.6 KiB) Viewed 10376 times
Member since 2005
Buoy
Postby Buoy » Sat Dec 17, 2016 12:22 pm
Wow--that 190 Outrage does seem to run deeper than the Dauntless. Thanks for taking the time to take the photos. admirable.
