posted 08-01-2011 08:25 PM ET (US)
It has been almost ten seasons since I purchased my 2002 180 Dauntless. This is a brief summary and review of what I have experienced during my ownership.I bought the boat in New Hampshire at a dealership located on Squam Lake. I found the service to be just fair; they seemed a bit to laid back. I don't think they were completely honest about the boat being ready for delivery during our negotiations including a Smart Craft upgrade that needed to be completed. Boston Whaler made up for this with very good factory acknowledgment of my purchase including a questionare regarding the dealership. I gave the dealership a good review.
When I got the boat home I found a poorly organized set of Smart Craft wires,some snapped of fasteners at a couple of locations, and a cushion with snaps that did not align properly. Not the end of the world, I usually work on my boats anyway and I wasn't going back.
I added a twenty four volt trolling motor on the bow. The batteries got located at the stern, starboard side, adjacent to the cranking battery. I modified the front rail by adding small 1-inch stainless steel flanges that allow me to quickly remove a short railing section when needed. I did have to cover the bow light when I bolted down an aluminum plate for the trolling motor but made up for this with a nice removable bracket. I found the wood locations to be accurate and that they can except even a fine thread; lots of 5200 sealant for the bow plate and battery boxes. I added the bow electrical plate, plastic, that locates a power port and the plug for the trolling motor. When I drilled out the bow section to gain access to the wire way I found water. I think this was left from when the boat was built. Running the wires was not bad although it did require the entire family and a metal snake. The trolling motor bracket has worked well including and accidental deployment while on plane that damaged the trolling motor; it's plenty strong.
I had a failure of both my anchor locker cover and stern seat back section. I had a dealership; Cambridge, Massachusetts help with the repair and I would give them poor marks. They would not purchase the new parts without seeing the boat, even after I offered a credit card number just in case they could not be replaced under warranty. They actually promised to do so and then did not have them when I dropped off the boat. This cost me fishing time. Also, they did not take the time to line up the anchor locker cover that caused a scratch the first time I opened and closed the lid. Even worse, I put a ding in my skeg going over a berm in their new parking lot. I fixed the ding with an orbital sander; 80 grit, looks like new.
Please remember that these are condensed experiences of ten seasons; I am not intending this to be a negative appraisal. I really, really, like this boat.
I added a Raymarine A65 at the helm. It was expensive. I would not do this again. Instead I would install a decent sonar at the bow, it is close enough to see from the helm, and a removable GPS at the helm that could get more usage in my car. The bimini top brackets are conveniently located immediately in between the front and rear railings, midship. It is a sharp pointy piece of stainless steel. It got me in the ribs one to many times when landing a fish and they are gone, gone, forever.
I bought Mills covers and they are a great product.
Blisters--I got very subtle indications that I was getting blisters. After some heated debate I had the boat lightly sanded, epoxy coated and bottom painted; about fifteen hundred dollars. No more worries about leaving my expensive boat in the water overnight, I do have bottom paint. It has worked well. My cushions after spending a lot of time in the elements are still excellent, very good quality. The O-ring at the top of my hydraulic steering reservoir failed. It took a while to figure out what was happening but turned out to be and easy fix. The boat gets mildew. The mildew is a real maintenance pain. Some of my caulking has grown mildew and it will not come out.
I hit a water sky at speed. I bought a color matched repair kit and I could not find the repair a year later.
I am on my second set of hubs and trailer bearings.
My switches have degraded from the sun. Not terrible, lights on and off, I don't think I have ever used the horn button. The doors to the helm will sometimes open if you really smack a good wave. They are very sharp at the corners and it is usually not a good time to be looking down and closing the doors. My scuppers, inboard, have cracked and been replaced two times. Next time I will just fill the cracks with 5200. I had to replace the straps that hold down the cooler seat. It is to be expected and I am impressed by how something so simple can work so well.
Second cranking battery in ten seasons! It may be time for a third battery. I can't remember seeing water being moved by my bilge pump. My boat is slow, slow and steady. I get about 36 knots. It's kinda a big stern heavy tank. It always has gotten us home. I personally would get in the Dauntless before a Montauk if things got rough. I also think the Dauntless at least equals the Montauk in looks.
My Mercury OptiMax 135 was on the losing end of a class action law suit. It has three hundred hours. I got a year extra warranty because of the law suite. I replace the impeller every year.I used to change the plugs every season. Now I go with the recommended one hundred hours.
My alternator stopped working and required replacement. It was about $600 repair. I had a really bad water intrusion in my gasoline. I got a water alarm twice. I sampled and emptied a water filter. I had to have the entire gas tank emptied. The engine never skipped a beat. It always starts. It always runs the same. My decals peeled off; how can Mercury not have good decals after so many years of selling them?
My intake cowl welds broke free, plastic inside the engine cover, and I had to have a friend tack them again, not to bad. I run and aluminum prop. It looks factory new, knock on wood. My lower end oil gets changed twice a year.
The 180 Dauntless hull design is gone. A much different design is now being used. I wouldn't buy one. To me Boston Whalers are the boat with the different and well thought out hull shape. I also don't see to many 180's for sale in the Northeast. I am very confident that this boat is destined to be added to the classic forum. It's just a matter of time.
