posted 10-21-2001 09:21 PM ET (US)
Electrical wiring from 1973, even if left high and dry and not exposed to the elements, would probably not be in much better condition than you describe. Those wires are over a quarter century old! Throw in exposure to water (maybe salt water), oil, gasoline, sunlight, heat, cold, abrasion, and constant movement and it is not hard to image the wiring being in bad shape.As for a diagram, there really is not much wiring to diagram. The connections to the engine are specific to the make and model of the engine. The wiring for the boat hull is probably limited to the running lights and perhaps a sump pump. |
