Topic: Low-boy vs. on-top trailer
Arch Autenreith |
posted 01-14-2002 02:05 PM ET (US)
My trailer has the keel-rollers mounted on the cross-members level with the frame perimeter. My bud’s Master Craft ski boat trailer is manufactured so that the keel rests below the frame perimeter. I can see a couple advantages. One is that it rides lower. That by itself lowers the center of gravity but the wheels, because they can’t be on a traditional axel use a torsion bar and the wheelbase is also wider which also adds to the stability while towing. Also, because it rides lower it would have less wind resistance if it were much above the height of the tow vehicle (as is the case with me). I would think that launching might be easier at some launch ramps as it would also float sooner and therefore I wouldn’t have to back so far into the water. Any other pros / cons I haven’t thought of? What say you all?Arch
russellbailey
posted 01-14-2002 02:28 PM ET (US)
Our 15' Striper is on a low-boy trailer, where the cross-members drop a bit below the side rails. It ends up with the hull about 15" off the ground.I like it a lot compared to our prior flat type, which rode about a foot higher. The gunwale is quite low and makes it easy to load stuff into it while on the trailer while standing on the ground. It also fits more easily into the garage. On the negative side, you have to trailer with the motor tilted, and there is not much room below the cross members for support hardware (bunk or roller attachments) without the possibility of the hardware dragging on rough road. I can see where on a bigger whaler a flat-type could be better, but for our little whaler I like the low-boy type better. |
triblet
posted 01-14-2002 04:20 PM ET (US)
My Montauk is on a trailer where the cross members drop below the frame. It has leaf springs and a dropped axle. I love it because the boat floats sooner.Chuck |
lhg
posted 01-14-2002 05:33 PM ET (US)
A proper trailer for most Whalers, particularly if equipped with keel rollers, should have a moderate "V" frame. See picture of the Nauset in 16 Reference section, or picture in Cetacea Page 4.Some trailers, however, actually have too deep of a vee frame, such as the Pacific brand, making it more difficult to convert to keel roller design if needed. |
Arch Autenreith
posted 01-14-2002 06:23 PM ET (US)
And here I thought I was in the majority with a non-V frame trailer. Oh well, at least my observations were more or less correct: the lowered version seems to be a better setup. I wonder if I could get new "v" cross-members at a reasonable price? Probably not. Now come to think of it I think they're welded on anyhow (then galvanized). Arch |
