ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Spring to-do list
Author | Topic: Spring to-do list |
Arch Autenreith |
posted 02-03-2002 08:41 AM ET (US)
Buy new rectifier. Paint consol top grey non-skid. Buff interior. Needle-nose pliers with insulated grips for toolbox. Booster cables. Digital Multimeter for toolbox. Copy of the engine's Operation & Maintenance Manual. Re-grease and tighten prop. Buy 2 new fuel strainer covers & gaskets Raise engine. Download latest software for Garmin 160 fishfinder. New inflatable life jackets. New Pelican case. Hooks for hanging stuff inside consol. Install white light inside consol. Wire to anchor light. Paint inside of searchlight black. Load test batteries. Install amp / volt meter Change impeller. It's already February! I better get to work. |
dfmcintyre |
posted 02-03-2002 08:55 AM ET (US)
Hmmmm. I like that like. Will have to pickup the life jackets and do a little wiring myself. Also need to pull off the brightwork and start the varnish work. Want to redo my fiberglass sleeping platform, and add two more sections to it. FWIW, if any of you are looking for some quality tools, order a catalog from: http://www.griotsgarage.com/handbook.jsp Beautiful stuff. Mac |
triblet |
posted 02-03-2002 09:12 AM ET (US)
I agree about Griot's having some nice stuff. But, like all good things, expensive. My spring list: Arch: when you buy the Pelican, do a little http://www.bhphotovideo.com/
Dr T |
posted 02-03-2002 12:11 PM ET (US)
Fortunately, the 13 has a much shorter list. First, It may take a while for the ice to thaw out up here. My list is something like: Get all of my wife's Christmas decorations out of the boat and into the attic. What is the best way to de-winterize a motor? I guess I could go diving like Chuck, but no one has been doing much ice diving up here this winter. tds |
JBCornwell |
posted 02-03-2002 12:28 PM ET (US)
Hey, Arch. "Paint the inside of the searchlight black." Huh? How come? Red sky at night. . . |
sorcerer |
posted 02-03-2002 03:23 PM ET (US)
I think he means the lens! |
sorcerer |
posted 02-03-2002 03:27 PM ET (US)
Arch Autenreith |
posted 02-03-2002 04:29 PM ET (US)
JB. My searchlight is of the inexpensive kind. 800 candle power for $20. The housing is white and when on it sort of 'glows'(?) which, aside from reducing my night vision is just irritating. I was just going to paint the outside black but a friend suggested doing the inside so it wouldn't scrape off. I know, sort of anal. Just one of those mindless things I thought of doing while waiting for the boating season to start. Chuck. I actually remember you saying you use Pelicans for all your stuff and when I saw one I realized that’s just what I needed. I need it for things like the fishfinder, camera, Palm, hand-held VHF, etc. I need the foam, don’t I? Arch |
posted 02-03-2002 05:01 PM ET (US)
Painting the inside black may cause it to absorb more heat. The lamp generates plenty of heat along with its light. |
LKS |
posted 02-03-2002 05:26 PM ET (US)
Inspect anchor, chain, and line, and replace as necessary. Check connections on VHF and other electronics. |
triblet |
posted 02-03-2002 10:18 PM ET (US)
You only need the foam if you are carrying really fragile stuff like cameras and are going to give it to the airlines. On the boat, I only use one with foam, and that pnly to carry one camera and lens when I go to the lake. On the ocean, it has my camera maintenance stuff (film, O-ring grease, that sort of stuff) without foam. And the only reason I use the foam on the lake is because I happened to buy this one with foam. Otherwise I'd just wrap it in a towel.
