ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Trailering: Calculations -- I disagree (a bit)
Author | Topic: Trailering: Calculations -- I disagree (a bit) |
triblet |
posted 03-28-2002 11:44 PM ET (US)
First: I think there's some really good stuff in the article. I've adjusted my tongue weight twice using what I believe to be the same calculations. Both times it ended up right where I expected it it. I moved it a second time because I decided I wanted even less tongue weight. BUT: I STRONGLY disagree with: "Moving the All I did was lower the trailer jack all the
Jerry Townsend |
posted 03-29-2002 10:39 AM ET (US)
Chuck - point understood - and certainly in your case where your axle is apparently unsprung - moving the axle would be quite easy. However, should one have a trailer with one or more sprung axles where the spring mounts are bolted to the frame - moving the boat (via moving the winch stand and boat) is a perhaps a bit easier. But, it makes little difference which way is taken - both roads lead to Rome - though one might be a tad longer. Appreciate your comment. ----- Jerry/Idaho |
triblet |
posted 03-29-2002 11:09 AM ET (US)
I have a sprung axle. It was still easy. Chuck |
JohnAz |
posted 03-29-2002 12:18 PM ET (US)
Thanks,,,Triblet |
JBCornwell |
posted 03-29-2002 12:53 PM ET (US)
I don't know what article I missed, but I agree with Triblet. The boat is moved only to get the support in the correct locations. Most important is support directly under the transom and/or keel. The carriage that fits the springs and axle(s) to the frame is moved to adjust balance of the whole rig to get 7% to 10% of the towed weight on the hitch for a single axle trailer, 5% to 7% for a tandem. Some carriages are bolted to the frame; move them anyway. If you need new bolt holes drill them or, even better, use "U" bolts to secure it. The easier arrangement holds the carriage to the frame with 4 or more "U" bolts. Then you merely loosen the "U" bolts and slide the carriage to the new position. If your spring shackles are bolted to the frame, rather than to a movable carriage you either have a trailer custom built for that boat, and no other, or you have a trailer too cheap to carry a Whaler. The above comes second hand from an engineer who used to work for Shoreline. He saved me a lot of grief. Red sky at night. . . |
posted 03-29-2002 03:21 PM ET (US)
The article to which Chuck alludes is http://continuouswave.com/whaler/reference/trailering/trailerCalculations.html . The topic of how to properly rig a trailer and position the boat with respect to the trailer frame is covered at length in http://continuouswave.com/whaler/reference/trailering/trailer.html Jerry Townsend's article is really more about pre-calculation of tongue weight changes that result from boat position movement than an exhaustive treatise on trailer rigging. |
posted 04-01-2002 08:32 AM ET (US)
Jerry Townsend has created a DOS executable program to aid in performing all the calculations he described. A link to the program is now included in the article. As for the one sentence of the article that Chuck objected to, I have added a hyperlink to my article on trailer rigging that explains the pro's and con's of moving the boat. I also added a hyperlink in that article back to the article on calculating the tongue weight. In the rigging article the notion of not moving the boat nilly-willy on the trailer to adjust the tongue weight is (I thought) well described and the benefits from rigging it that way are presented. If a boat is on a bunk trailer, I don't think that moving the boat farther forward is really a problem. You'll just be moving more onto the bunks. In the case of keel roller trailers, Actually, on my trailer, the bunks extend well past the transom. At one time the boat was rigged with the transom about a foot farther aft. As I recommend in my article, I moved the boat to where I wanted it to rest on the trailer, rigged the trailer rollers and bunks, then moved the axle to get the tongue weight. When I finished I had a foot of bunk sticking out the back. |
triblet |
posted 04-01-2002 11:02 AM ET (US)
I also have a bunk trailer. Again, moving the boat would have been a lot more work. Since I was reducing the tongue weight, moving the boat aft was not an option. And had I been trying to increase the tongue weight, moving the boat would have moved my truck closer to salt water when launching. Maybe it's different if you launch in fresh Chuck |
Jerry Townsend |
posted 04-01-2002 03:18 PM ET (US)
Chuck - the choice of moving the boat or the axle(s) is that of the owner of the outfit and in the case of your boat - the decision is yours! But, you have two choices - either the boat or the axles - either (or both) will do the job. The write-up simply presents the necessary formulations for those interested to get an idea of what is going to be required. That is, if a hitch load is too light or heavy, the owner can get an idea on how much the boat and/or the axles need to be moved. The trailer load balance write-up addresses each option and does not make a recommendation, per se, regarding moving the boat or axles - as that decision rests solely with the owner of the outfit. Also, trailer load balance adjustments normally require the boat or axles be moved but a few inches - not feet. The reason for this is that the boat weight is principally carried by the trailer wheels and the C/G of the boat being but a few inches in front of the axle. Jim has provided a very good write-up in the REFERENCE section regarding many aspects concerning a trailer. Those words are appropriate and germane. ----- Jerry/Idaho |
triblet |
posted 04-01-2002 10:28 PM ET (US)
I agree that it's the choice of the owner, but it DOES make a recommendation: The page says "Moving the boat is easier". Not only is this is wrong (which makes more work for the owner), but moving the boat is potentially damaging to the boat. I checked out the trailers in the launch Moving the boat requires moving that which
Jerry Townsend |
posted 04-04-2002 11:33 PM ET (US)
Chuck - I finally got back to the FORUM - and indeed I make the statement that 'moving the boat is easier ...'. The word 'is' is wrong and should be 'might be' or 'could be' or something else. I wouldn't even think of opening a discussion regarding '...it depends on what the word is - is ...'. But seriously, hopefully I have not made any more errors in the poor choice of words - but, if I have, consider that word in the context of the remaining text. ----- Jerry/Idaho |
lhg |
posted 04-05-2002 02:11 PM ET (US)
I agree, adjust the trailer wheels. Here's an even easier way to do it, and the method I use on my dual axle 25 Outrage trailer, with 4 wheel disc brakes. Having previously marked the frame for distance to move the wheel carriage, get the boat off the trailer, leaving trailer attached to the car (so the frame remains fixed in position), loosen the four U-bolts clamping the carriage frame to the trailer frame, roll the wheel assembly forward or backward as necessary, working side to side an inch at a time, retighten U-bolts. No jacking is necessary, as the wheel carriage will slide easily relative to the frame. It's a 1/2 can of beer job! |
