ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Need specs for a 1981 24"7" Outrage
Author | Topic: Need specs for a 1981 24"7" Outrage |
Marco Whalo |
posted 04-07-2002 02:57 PM ET (US)
I looked through the site but could only find specs up to the 22ft. models. Thanks...MW |
Tom W Clark |
posted 04-07-2002 03:07 PM ET (US)
You'll find them here: http://continuouswave.com/whaler/reference/specifications.html |
Tom W Clark |
posted 04-07-2002 03:26 PM ET (US)
Ooops, you'll not find them there. Precisely what specifications are you looking for? |
posted 04-07-2002 11:45 PM ET (US)
Still working on the specs for the larger boats. There are many variations in the boats, like Outboard/WhalerDrive/SeaDrive/GillBracket/I-O/Inboard powering, then add models like OUTRAGE, TEMPTATION, REVENGE-WT, WALK-AROUND, FULL CABIN, CENTER CONSOLE CUDDY...well, there are a million permutations. |
Marco Whalo |
posted 04-08-2002 07:19 PM ET (US)
I am looking for the same general specs (weight, max HP) as are included in the table above but for a 1981 24'7" Outrage, outboard without WD or a cuddy. Since it is an Outrage there may be only a thousand permutations :-). Thanks...Mark |
lhg |
posted 04-08-2002 08:02 PM ET (US)
In 1982, they changed the name to 25 Outrage. Center console, notched transom model weighs 3300lbs. Beam is 8'-0". Rated for twin 150's, the power of choice. The boat was designed for twin 20" engines, but I recommend using transom brackets and buying 25" Counter Rotating engines. |
