Topic: 13' dimensions
whalerfever |
posted 05-31-2002 11:23 PM ET (US)
Hello--I'm a new member, looking at 13' Whalers, old and new (don't have one yet). Although their sizes are largely the same, I'm a little puzzled about the differences, say, between a mid-80s and a late 90s boat. For instance: Older boat = 13'4" L, 65" beam, 320 pounds dry wt. Newer boat = 13'3" L, 71" beam, and 600 lbs. dry wt. Newer boat appears to weigh about twice as much, but has less maximum weight cap. (935 pounds vs 1200 lbs older boat). I assume that the extra width adds more weight to the newer boat, but why does it have less carrying capacity? One more stats-type question: I see that newer 13' boats list a maximum engine weight of 210 lbs. Would anyone know what the max. engine wt. should be for an '85-'94 13' Sport? By the way, your web site has been an invaluable guide to learning about the various models and choices available. It has also been a lot of fun to read people's stories and tips. Thanks in advance for your time....Mike
posted 06-02-2002 12:20 PM ET (US)
Hi Mike,You are comparing the "classic" 13-foot hull with the much more recent 13-foot hull. The new hull weighs more probably because it has more glass/resin and less foam. That also explains the reduced floatation rating. The modest increase in buoyancy of the larger hull was more than eaten up by the higher weight. I don't know that a maximum engine weight rating was ever applied to the 13-foot classic hull, but outboards weighed much less in 1960 than they do today. Of course, the 1960 Whaler was much lighter weight, too, so it needed a smaller motor. It is not unusual to see a motor rated 40-HP at the prop on a modern 13-foot Whaler. In the 1960 it was much more typical to see an engine rated as 25-HP (at the power head) on a 13-Whaler. Maybe it's because the people got bigger! I think my Dad only weighed about 175# in the 1960's, while I'm struggling to get under 215# these days--that might explain the bigger motors. We used to have an 18-HP JOHNSON that he could easily lift into the trunk of the car. I am sure that motor weighed less than 100#. Welcome to the forum, --jimh |
posted 06-02-2002 12:33 PM ET (US)
Also meant to say:Another factor in those 1960's motor weights was the pratically universal lack of electric start, power tilt or trim, and battery charging. That cuts about 100# off the weight of the engine right there, plus it eliminates a 50# lead-acid battery. We used to operate the running lights on a lantern battery cell. The engine was pull start. Trim was set by a mechanical stop pin. Life was simpler. |
AllanR
posted 06-02-2002 01:39 PM ET (US)
AllanR I had a 1982 13' for 12 years. It had a 35 Johnson.No power tilt or trim. It was plenty of power. Very stable. A pounder in rough water. I loved the boat, but sold it in 1994 for a new Montauk. I wanted to be able to stand up and walk around in the boat. Both of them have fit in my garage. But I feel much more comfortable in the Montauk. I think the new 13 has a more deep v entry in the bow, so it must ride a bit better than the old one, but needs more power with the extra weight. But I have to say that the old one was extremely stable and floated like a cork. I could have six people in it and never worry about it. By the way. I bought the 13 new in 1982 for $5,000 with the works, trailer, top, cover etc, kept it 12 years and sold it for $4200. Can't beat these things. |
whalerfever
posted 06-02-2002 06:48 PM ET (US)
jimh and AllanR--Thanks for the replies. I was especially interested to learn about the differences in classic and new 13' hull construction in terms of proportions of glass vs foam. Re engine weight: I had not considered in any depth the differences between new and old engine weights, and had also not factored in the various extras (e.g., t/t) that add to the weight of modern engines. Thanks again for the great info....Mike |
familyg21
posted 06-02-2002 07:14 PM ET (US)
i am selling a 1980 hull 1989 yamaha 30 hp and trailer in great condition if you are intersested let meknowfamilyg21@hotmail.com take care
jimithing
posted 06-03-2002 11:05 AM ET (US)
familyg21was wondering what you were looking for pricewise for that boat of yours. Thanks |
