ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Engine Horsepower Ratings
Author | Topic: Engine Horsepower Ratings |
quickfarms |
posted 11-25-2002 02:46 PM ET (US)
I was told that the newer engines are more powerfull than the older ones due to a change in how the horsepower was rated. I was told that the old engines were rated at the flywheel and the new engines are rated at the prop. Is this true and if it is when did the change accur? |
Tom W Clark |
posted 11-25-2002 02:55 PM ET (US)
Yes, that is true. The change came in the mid 1980's. I'm not sure it occurred at exactly the same time for all manufacturers but I know that OMC was rating their motors at the prop by 1984 or 1985. |
Bigshot |
posted 11-25-2002 03:16 PM ET (US)
depends on the engine size. Larger ones were rated earlier. Suzuki/Yamaha always rated at the prop. All engines had to convert to priop ratings by 1986 I believe. |
frank_king |
posted 11-25-2002 10:11 PM ET (US)
you are correct bigshot, 86 was the year that the motors had to rated at the prop. |
posted 11-26-2002 12:00 AM ET (US)
This question has been asked several times, but so far all answers have been strictly hearsay. Can anyone point to an online authorative source that cites a particular date? |
Bigshot |
posted 11-26-2002 08:46 AM ET (US)
Can you prove you are really Jimh? |
posted 11-26-2002 10:54 AM ET (US)
If there is a federal requirement about how outboard engine horsepower is to be rated, there ought to be some text out there, somewhere, that could be cited. It may be entirely correct that in 1986 the rules changed, but it would be nice to have this on a little more authority. |
Tom W Clark |
posted 11-26-2002 11:17 AM ET (US)
The standard by which outboard motors are rated for power is the International Council of Marine Industry Associates (ICOMIA) standard 28/83. You can read it here: Among other things, it says outboards are to be rated at the prop shaft and that rated horsepower is to be within +/-10% of measured horsepower It does not, however, state when this standard was put into effect. |
Tom W Clark |
posted 11-26-2002 12:19 PM ET (US)
The standard number itself (28/83) suggests it was written in 1983. Note that this is an industry standard not a federal (or other) regulation. As such I would presume it is a standard to be adhered to by members of this organization. |
Bigshot |
posted 11-26-2002 01:38 PM ET (US)
I know in 84 OMC started to change over. They turned the 200 into a 185, etc. In 1985 they changed the 35 into a 30, etc. In 86 they got rid of the 60 2cyl, knocked the 235 to a 225, 115 to a 110, etc. 1987 was unchanged so I believe everything was set by then. I do not have any proof but I am near positive. 1984 was also the 1st year I believe they started rating them in KW. Does not however mean the KW was prop KW. I know Merc used the KW rating in the late 70's but not sure if it was head or prop rated. My 1981 Suzuki was rated at the prop, so was my 84 Yamaha 30hp. |
lhg |
posted 11-26-2002 07:03 PM ET (US)
My 1984 Merucry in-line-6 115 was prop rated. This was clearly stated in the specs. |
daverdla |
posted 11-27-2002 08:36 AM ET (US)
According to section 7 on the third page the tolerance drops to +/-5% on governed units and on units 100kW or greater. Dave |
daverdla |
posted 11-27-2002 09:04 AM ET (US)
Oops, make that greater than 100kW (134HP). If you're at 100kW could be 90 to 110. 101kW is limited to approximately 96 to 106. Ten percent does seem like a large range. I wonder with all of the newer manufacturing equipment available if the manufactuers couldn't limit the range. I don't think I'd mind +/- ten percent on a 5HP outboard. It doesn't seem reasonable to have such a large variation on say 100HP. Dave |
RMS |
posted 11-27-2002 09:11 AM ET (US)
Dave, that 10% variance is very useful to the manufacturers. As an example, Yamaha could market a 95hp outboard as a 100hp, and sell the same engine to Mercury to be marketed as a 90hp. Bob |
Pat Mac |
posted 11-27-2002 09:28 AM ET (US)
My 1984 Johnson 70 is rated at the head, per the manual. Pat Mac |
lhg |
posted 11-27-2002 02:39 PM ET (US)
RMS - on that particular Yamaha/Mercury 4-stroke you are referring to, for 2003 Yamaha has dropped their 100HP rating down to Mercury's 90 also. This is the engine offered on the new Montauk 17. |
Hank |
posted 11-27-2002 10:41 PM ET (US)
My 1984 90HP Evinrude is rated " at the propellor shaft according to ICOMIA 28-83". Quotes are from the manual. Manual covers the 115HP and 140HP of that year. All are rated at the prop shaft at 5000 RPM. Hank |
Tom W Clark |
posted 12-01-2002 12:29 PM ET (US)
daverdla makes an astute observation. If Dave and I are reading ICOMIA standard 28/83 correctly, then any outboard rated at over 134 hp needs to be rated within +/- 5% of actual horsepower at the prop shaft. But this flies in the face of the +/- 10% margin we have always heard about. In fact, Evinrude's own web site plainly states that their 200 hp motor puts out nearly 220 hp! (which, by the way, makes Sal DiMercurio's 200 Evinrude Ficht pretty much run-of-the-mill if it dyno'ed at only 212 hp.) Can anybody explain this discrepancy? |
Crabby Mike |
posted 11-04-2003 06:32 PM ET (US)
Hi all,
I just read the thread on the release of the E-Tech engine from Evinrude and went to the web site to see if how the horsepower ratings were determined. All I could find is that the ratings comply with the ICOMIA 28/83 standards. Went to ICOMIA and could not locate the standards, other than that the power is measured at the prop shaft. I recently read a magazine review of a boat-motor combo and saw that the horsepower was rated using M - HP never seeing M-HP before I read the article carefully and found M-HP (Metric Horsepower) which is less than B-HP (Brake Horsepower). The reviewer stated that many motor builders from overseas like to use the M-HP because they can advertise a bigger HP number. My question is dose the ICOMIA 28/83 standards specify Metric or Brake Horsepower? Could the differences in performance that some members are experiencing be caused by some companies are using brake horsepower and a competitor is using metric horsepower? Mike |
kglinz |
posted 11-04-2003 07:01 PM ET (US)
HP ratings are corrected to the power that an engine will produce on a "standard day" A standard day is: Sea level, 30% relative humidity at 25 degrees C temp,and 29.61 inches of mercury barometric pressure. My book says a hot, humid day could cost you as much as 14% power loss. The rating standards a set forth in I.S.O 3046. |
lhg |
posted 11-04-2003 07:12 PM ET (US)
You might be on to something. All of these conventions are news to me, but it would explain the general perception, and from my own personal experiences, that the Japanese engines, on a HP to HP basis, don't seem to be as powerful as the US built Mercury and OMC engines (talking 2-strokes here). Then add into this equation the 10% up or down fudge factor, and it's hard to tell what you're really buying. Take the highly popular 2-stroke 90's. Both the OMC and Mercury versions will outrun the lighter weight and smaller Yamaha and Tohatsu versions. Nick here has said he thought his Yamaha 90 was putting out about 82 HP. I know of a situation where an owner of a 1991 200HP Yamaha was told, by a Yamaha mechanic who also had experience with other brands, that the engine really only puts out about 175 HP. Having paid a high price for 200 horses, he was not too happy. The reliability of that engine, with I think about 500 hours on it, however, has been excellent. Conversely, I have been told that my 1997 Merc 200 EFI's are really putting out more than 200HP each. In racing versions, Mercury gets 260HP out of these. The 225 Mercury EFI has been indicated at more like 240 HP, and the same block is good for the 300HP version. It's been no secret that Mercury's rise to fame in the outboard market was partly based on deliberate under-rating of HP. One of their really early engines was a little green painted 10 horse model, that would walk away from an OMC 10. It also appears that with more recent models, this foreign motor HP discrepancy is disappearing. Most recently Yamaha learned this lesson with their 4-stroke 80's and 100's, which Mercury sells as identical engines at 75 and 90HP. For 2003, Yamaha gave in and marked their 80/100 engines down to Mercury's ratings of 75 & 90. One must think that the only reason for the higher, probably unsustainable, HP ratings was to get a bigger price for the motors. |
kglinz |
posted 11-04-2003 07:37 PM ET (US)
You know, in my opinion it's not the number on the decal on the back of the motor that makes a good boat/motor combination. The thing that matters is, is the performance that you want. We have, owned by members of this Forum, examples of about every Boston Whaler/Motor combo you could come up with. Before anyone spends $30k on a boat or $15k on a motor he should make a post looking for a sea trial in what he's considering. He might spend a few hundred dollars but he'll know what he's getting. I know I'll give you ride during the summer, but you'll probably need a float plane ride to meet me. |
Crabby Mike |
posted 11-04-2003 07:55 PM ET (US)
I just went to Suzuki’s web site and found that the DF 140 is rated for 103 kw Brake Horsepower is 746 watts so a 140 x 746=104,440 shouldn’t the engine be rated at 104,440 watts or 104.4 kw. I looks like the actual brake HP produced is 134.45 hp, 103000 / 746=134.45 On the Evinurde site the 135 DI is rated for 107 kw , 135 x 746=100,710 are the Evinrude engines producing more power than advertised? Suzuki 140 producing 103 kw while the “lessor” Evinrude 135 puts out 107 kw Hummmmmmmmmmm Mike |
captbone |
posted 11-04-2003 08:06 PM ET (US)
They are allowed to be within 10% plus or minus. Some do the minus side to have a lighter wieght motor that is slightly less powerful and so do it to have the most powerful engine in the class. A 135 can legally be a 150 in 135 stickers (I think a few companies used to do this.) |
Crabby Mike |
posted 11-04-2003 08:27 PM ET (US)
I agree that there is a 10% fudge factor +- the rated HP, What I am trying to find out is that 10% based upon Brake HP or Metric HP. If one manufacture uses the metric standard then when we see an hp rating we are not buying the power that we think we are. I thought that the 10% spread was for taking an engine off the line and testing it for actual power produced. So some engines pulled from the line (rated for 135 hp) could produce as few as 121 hp or as much as 148 hp and still be within specs. not for advertising purposes i.e. knowingly producing an engine that will give only 121 hp and putting a 135 hp sticker on it. Mike |
lhg |
posted 11-04-2003 08:58 PM ET (US)
I think this discussion is getting real close to one of the reasons I buy Mercury Outboards - getting more HP than I am paying for, as opposed to less HP. |
kglinz |
posted 11-04-2003 09:07 PM ET (US)
Do you think we could talk the manufactures into pricing motors like beef, but instead of by the pound we could dyno the engine we like the size and look of and pay by the horsepower. |
dgp |
posted 11-04-2003 09:16 PM ET (US)
1 kW (mechanical) = 1.341 brake HP. 1 brake HP = 1.01387 metric HP. |
Crabby Mike |
posted 11-04-2003 11:31 PM ET (US)
Kglinz, not my intent at all but I have read in various threads where one is trying to determine what engine to purchase, while I think it really comes down to that you take you pick and enjoy your boat. I do think it would be nice to have everything on a level playing field while trying to decide. You have the best idea, before buying an engine try to ride in a rig with the same setup. With regards to how the power rating is made, Evinrude site didn’t mention ISO 3064 only that they comply with ICOMIA 28/83 what ever that means :-) Dgp, now I am really confused… Say goodnight Gracie, Mike |
captbone |
posted 11-04-2003 11:42 PM ET (US)
Almost all companies use the 10% fudge factor to make their engines stronger or lighter than the other. Evinrude had the 225 H.O. that made 247hp recently and for years in the 40s-50s, the mercury head constantly underrated his outboards great so they would with the class of racing. The japanese engines seem to go the other way with the 140 tohatsu and 140 suzuki that get their door blown off by the 135 evinrudes and Mercs. Each company does it for different reason. I think if you are aware of this in each hp class then it is simple to see which is the most powerful and which are the lightest, most compact and fuel economic. |
posted 11-05-2003 08:06 AM ET (US)
(This is an old thread that was recently revived in November of 2003. Unfortunately, the hyperlink to the reference ICOMIA site is no longer working.) |
posted 11-05-2003 08:18 AM ET (US)
(Administrative post) |
daverdla |
posted 11-05-2003 09:10 AM ET (US)
Unless it's been revised, the fudge factor drops to 5% above 100kW. Dave |
Tom2697 |
posted 11-05-2003 09:49 AM ET (US)
When performing a mechanical design, you always shoot for the nominal (ie - rated horsepower). When manufacturing, you aim for the nominal but usually never hit that target. The +/- 10% range is to make up for variations in the fabrication and assembly of the components. One part might be above the nominal, the next below. Statistical control procedures state that you are not producing in control if more than 7 sequential assemblies all fall on one side of the median value. What this means is that no company that is ISO 9001 rated will attempt to produce all engines on one side of the nominal specification. Of course there will be trending (where the nominal specification actually lies) but the companies will always try to match the nominal, or at least the trend. In english: A motor designed to produce 150 hp can produce between 135 hp and 165 hp. But, one motor will not produce 135 and the next 165. If this was the case, the company has design, supplier, or manufacturing problems and their costs will increase substantially. But, they will try to produce motors in the range from 145 to 155. This will allow them to make adjustements to their production before an issue becomes a problem. What trending means is that, instead of 150 hp being the nominal, 155 becomes the nominal. The range of "in control" production then might become from 150 to 160. Trending is extremely common in manufacturing. Unfortunately, one month may be trended on the high end and the next might be trended on the low end. There are a lot of variables to include to determine where the trend is...This helps explain why one person's boat does not perform the same as another's that is similarly equipped. Of course, this is all a GROSS generalization of tolerancing and process control. |
kglinz |
posted 11-05-2003 10:36 AM ET (US)
I agree with Tom on no two mechanical devices being the same. When I was in the "heavy equipment" business one of most troublesome things you could do was sell two "Identical" pieces of equipment to the same customer. You could not make them the same. One always had quicker hydraulics or more power or burned more fuel or sounded different. |
BQUICK |
posted 11-05-2003 02:16 PM ET (US)
Torque is an important factor. In cars and trucks they trump up hp ratings when torque at low rpm is what really gets you moving. The Toyota Tundra trucks boast that they have more torque but it's at a higher rpm than the others, so you have to rev it higher to see it. Same with alot of newer cars.....lower torque numbers than hp at at high rpm. I wonder why the OB manufacturers never rated torque???? Bruce |
skred |
While chatting with a dealer a while back about horsepower ratings, we agreed that in the '80's, manufacturers began rating hp at the prop shaft vs. flywheel. This dealer then confounded the issue by saying there's now a different rating: that it's rated (little fuzzy here) either at the shaft before the gearbox, or at the prop itself - as opposed to the prop shaft. I seem to recall him saying the rating at the prop itself would be less than at the shaft. Couldn't this then allow manufacturers to list hp as - say - 100 at the prop, but in actuality it measures 115 at the propshaft, or even higher at the shaft before the gears? |
Bigshot |
posted 11-05-2003 02:29 PM ET (US)
Prop shaft HP. Just like in cars it is the rated at the rear wheels, not at the tires. |
lhg |
posted 11-05-2003 03:01 PM ET (US)
I have owned 3 sets of Mercury twins. To this day, the power trim works at different trim speeds on each set, requiring additional adjustment to get them trimmed the same! One always works faster than the other. There probably are minor HP output differences too, but I have been unable to determine that. So this would support the manufacturing tolerance discussion. My only point with all of this is that outboards ARE priced by the HP (within a given technology), so manufacturing tolerances aside, I think it is unethical and deceptive business practice to use this 10% or 5% factor on the low side. On the high side, there is no loss to the consumer, and the buyer is assured he is AT LEAST getting what he paid his money for. If someone is selling a 140hp engine, it darn well should be faster top end than the other guy's 135. Technologies and gearing can make a difference in Using the new 170 Montauk as an example, where you have a choice of a Mercury 90 HP or a Mercury 90 HP!. They should both run the same top end, I would think. If the 2-stroke is faster than the 4-stroke, or vice versa, BW should make that information available to the buyer. If the 4-stroke is putting out a true 90HP, but the 2-stroke is putting out more like 100HP, they should tell you. The opposite would also apply, as I have no idea which engine performs better. |
kglinz |
posted 11-05-2003 03:25 PM ET (US)
As Bruce states, torque is very important and isn't given by the builders. The power I need is not at top RPM. I have decals on my motors showing 225 hp. That, by the HP/Torque charts I have is at 6000 RPM. I run at 4200 to 4500 RPM cruise. By my chart, at that RPM range the motors are producing between 150 and 175 HP each. I, in 110 Hrs of running, have used WOT (225 Hp) less than 10 minutes. I need to have enough power that when in "rollers" and going up a "hill", starting at 4200 Rpm, I don't lose RPM and speed and fall off plane. No published HP rating will tell you what will ocurr in your boat under a given condition. When I was a bass fisherman in Texas, it was a whole different deal. I used every HP I had. If I could stay in the boat at WOT I ran WOT. |
Tom2697 |
posted 11-05-2003 04:33 PM ET (US)
In today's market, no company wants to give away something for free. If they can charge the customer for it, they will. Unless a company has relatively unlimited resources and only wants to gain market share, they will usually offer exactly what the customer asks for and nothing else. Otherwise, they will kiss profits away. The cool thing about outboards is that most of the companies that make outboards do not make these as their main product line and so can offer a little extra without having it destroy their bottom lines. As for torque, I wish these values were listed as well. Only problem is, most consumers don't even understand torque when dealing with cars. So, here is another marketing/engineering trick: If you can produce the same horsepower motor but with less torque by having a smaller displacement, you will benefit by having a more efficient engine. Thus, you can truthfully advertise another thing that the consumers are looking for today, fuel efficiency. Most people don't ask "how quickly does your boat plane?" They ask how "fast does it go?" and "what type of range do you have?" Until we, the consumers, change our train of thought, most of the manufacturers will not change what information they provide to us. |
hauptjm |
posted 11-06-2003 10:59 AM ET (US)
Regarding torque: Are the dynamics of torque the same in water as they are on land? It seems the RPM of the propeller turning through the water is what moves the boat. The loads seem to be a constant until you reach planning speed, then they reduce. Therefore, you only have two variables in load. (I know this is an over simplification) If this is incorrect, then the prop would be slowing down due to load and the lack of torque, whereby the prop would not be turning the RPM indicated. It seems if the engine horsepower is large enough to turn the prop at the desired RPM, then the hull will react accordingly, regardless of one engine's torque versus another. Ex: Two 150HP engines of different brand turning the same prop on the same hull, turning the same RPM will move the hull identically. They're power band may be different, but the resulting force on the hull should be the same. Is this all wet? I'm sure there is an engineer among us that can explain this to us. |
hauptjm |
posted 11-06-2003 11:02 AM ET (US)
Their power band...sorry! |
jstachowiak |
posted 11-06-2003 11:10 AM ET (US)
I heard about this story on the radio and found this appropriate article about the automakers and horsepower. Looks like they are going to try and define "horsepower" more clearly since some automakers fudge the numbers. http://www.presstelegram.com/Stories/0,1413,246~25895~1712385,00.html Changes coming for horsepower, torque numbers Car owners may soon gain more confidence in the horsepower that automakers claim for their vehicles. A group of engineers is developing a new standard to verify automakers' claims for the power their engines develop. In the recent past, automakers from Jaguar to Hyundai have admitted they advertised unrealistically high output numbers for their cars. "Horsepower numbers are absolutely important to our readers," said Frank Markus, technical director of Car and Driver magazine. "It's one of the most crucial numbers. It's how we tell them why one car is better than another." The Society of Automotive Engineers is revising its standard for measuring horsepower and will suggest automakers have an independent observer verify the numbers they claim for horsepower and torque, said David Landcaster, General Motors Corp. engineering group manager and chairman of the SAE committee developing the new standard. One horsepower is the amount of force necessary to lift 550 pounds 1 foot in 1 second. SAE has developed standards for everything from motor oil to vehicle electronics. The new standard will also set a procedure for how to test torque, the other main force automakers advertise. Torque measures the turning force generated at the wheels. While high horsepower numbers generally equate to higher top speeds, torque determines a vehicle's acceleration and ability to pull heavy loads. "Companies have always been able to claim whatever horsepower they wanted," Markus said. "Adding some accountability for the numbers would be a good thing." Car and Driver caught Jaguar claiming 10 more horsepower than its high-performance S-type R model actually developed a couple of years ago. The automaker then revealed it used a test procedure that gave it higher numbers than what is generally accepted by engineers. Automakers can test for horsepower and torque in a variety of ways ranging from testing an engine sitting on a bench to evaluating the actual power transmitted to a vehicle's wheels. Ford and Mazda have also had to lower the horsepower they claimed some of their cars produced. "It makes you suspicious when a car claims more horsepower but has less performance," Markus said. "Some companies go with the number they like, especially when it gives them a nice round number like 400 horsepower." The current test, which was last revised in 1970, allows automakers to claim horsepower and torque figures higher than what most owners will actually experience, Landcaster said. Ford, GM and DaimlerChrysler support the idea of a new independently verified horsepower test. The new standard should be written by the end of the year, Landcaster said. An SAE advisory committee will then decide whether to adopt the procedure and the use of outside witnesses to verify automakers' claims. |
Tom2697 |
posted 11-06-2003 11:57 AM ET (US)
Horsepower is work/time. Work is force*distance. Torque is force*radius. What determines torque in an engine is the piston diameter (bore), the compression ratio, and the length the piston moves (stroke). The larger the bore or the higher the compression, the greater the force that is exerted on the piston after combustion. (Force = Pressure*Area). The longer the piston moves, the greater is the radius (stroke=2*crank radius). The bore and stroke also make up the volume of the engine (cubic inches). Now, take the forces that are exerted on the piston and factor in the rpm and you essentially get the engine horsepower. Of course, there are inefficiencies throughout the engine and the drivetrain (lower unit and prop for boats) that will rob the engine of horsepower. Prop slip is a major factor in robbing "horsepower" from a boat. For the boat, the drag force on the hull is proportional to the speed of the boat both above and below planing speeds. The drag is related to the area of the wetted surface of the hull (unlike friction) basically because more water is displaced by the larger "contact patch", hence why trimming the motor also increases speed. The motor most supply enough force to overcome the drag force at a given speed to accelerate the boat to a higher speed. It is also not a linear relationship and I don't know off-hand what exactly the relationship is. What does this mean? Two engines, pushing identical boats, using identical props, will differ in speed based on the inefficiencies in the engines and the wetted surfaces of the boats. Thus, if one motor weighs more than the other, the boat will sit lower in the water and will go a little slower...albeit not much. OK...now my head is hurting. |
bluerunner |
posted 11-08-2003 12:52 PM ET (US)
Hauptjm, I am not an engineer, but I do believe your example is exactly right. Two identical boats with different engines that are both turning an identical prop at the same RPM should reach the same speed. If they are not reaching the same speed it is due to factors that are causing differences in prop slippage. Tom2697's point concerning the possible effect of a heavier engine on the wetted surface of a boat is a good example of a factor that might increase prop slippage. |
Eric |
posted 11-08-2003 01:21 PM ET (US)
Excellent thread. I've been wondering why torque isn't addressed when discussing outboards. I think that it's got to be a factor when considering powering a boat with twins, and whether the boat will plane on one of the motors. If a motor will make peak torque at 5000 rpm, and another motor makes peak torque at 3500 rpm, which one would lift a heavy hull onto plane easier? They could still make the same total horsepower, and thus have the same power rating. The real world example of this is the johnson V4 90, when compared with the 3 cylinder 90s of other brands. |
lhg |
posted 11-08-2003 01:49 PM ET (US)
It should also be mentioned that 2-stroke engines, whether they be conventional or DFI, have much better acceleration because they get a power stroke twice as many times as a 4-stroke does. This is what gives them the low end punch and acceleration. In cars we overcome this with transmissions, but these are not used in outboards. This is why the conventional 4-strokes are "drag race dogs", and why initially, Mercury and OMC put their money on the 2-stroke DFI's instead of the 4-strokes. What they didn't count on was the five years of customer experience it took to get them perfected, which now does seem to be the case. Obviously this 4-stroke acceleration problem has troubled performance oriented Mercury, which is why their Project X 4-strokes will be supercharged. These, I have been reading, accelerate FASTER than a 2-stroke. |
Tom2697 |
posted 11-10-2003 10:13 AM ET (US)
Gearing is also critical. In Suzuki's brochure for their 140hp 4-stoke, they compare the hole shot and top end of two identical boats powered with a 140hp 2-stroke and a 140hp 4-stroke. The 4-stroke is geared much lower and hence can swing a bigger and higher pitched prop. The 4-stroke had better holeshot and better top end than their 2-stroke did. Technology is coming around with variable timing and supercharging to improve 4-strokes to where 2-strokes will become obsolete. |
Bigshot |
posted 11-10-2003 02:24 PM ET (US)
Two smokes are already obsolete....in certain states. |
lhg |
posted 11-10-2003 02:28 PM ET (US)
Unfortunately, some of the current 4-strokes are also obsolete. We won't mention names, but those that have them already know it. |
Tom2697 |
posted 11-10-2003 03:02 PM ET (US)
Some of the "current" 4-strokes are not so current.... |
