posted 05-21-2003 11:52 PM ET (US)
The author of this thread has confused the Unibond process, the Accutrack hull, and the "classic" Outrage hull.Unibond is the process by which Boston Whaler makes all their boats. Literally every catalogue they have produced contains information on their Unibond process.
Accutrack refers to a hull design intoduced c.1990 (I don't have the exact date handy--does anyone?). The Accutrack was built with the Unibond method. It was just a different hull shape.
The "classic" Boston Whaler hull was built with Unibond techniques. I don't know that Boston Whale ever gave it a trade name (like they did for Accutrack) but we refer to the "classic" hulls as those designed by Fisher, Hunt, or Dougherty, and typified by the classic 13-foot and 17-foot hulls. You can also consider the c.1985 Outrage hulls used on the 20, 22, 25, and 27-foot hulls as a "classic" if you like.
In this sense and in the sense of your original question ("Classic construction ended which year?") the proper answer is that classic construction has never ended. The Unibond process is still in use.
If you want to know when the Accutrack hull was introduced, again, that is around 1992 or so.
The Commercial and Government Products division has been molding boats with the classic 20-27 foot "Outrage" hull and continues to have them available in boats they call GUARDIANs.
To make things more complicated, the current labeling seems to be split into three styles of hulls:
--so-called "classic" hulls as seen reprised in the newly designed 130-SPORT 150-SPORT and 170-MONTUAK models;
--the Accutrack hulls, seen in models like the DAUNTLESS and VENTURA
--a newly named OUTRAGE hull now used in the more recently Outrage models, but not the same as the c.1985 Outrage hulls that we refer to as the "classic" hull. This new designation of "Outrage hull" applies to boats like the 270-Outrage and feaures very tall gunwales and a more pointed bow.
This can be quite confusing, and may require further comments from other knowledgeable authors to get completely straight.
