Topic: Mooring anchor for 13'
DaveNJ |
posted 06-03-2003 09:20 AM ET (US)
I plan on mooring my 13' in CT this summer for 2 weeks out in front of our rented cottage. It is the Long Island Sound, protected by jetties every 200' or so.If it gets bad, I will pull out and put on trailer. What kind of anchor should I use ? Are digger or fluke anchors OK or should I use a 5 gallon bucket or keg filled with cement ?
BQUICK
posted 06-03-2003 11:29 AM ET (US)
I wouldn't trust an anchor unless it was a mushroom. I made one like you said with a chain and 5 gal bucket filled w/cement. Easy to haul back in..... |
jimp
posted 06-03-2003 02:34 PM ET (US)
DaveNJ - We moored a 13 ftr in Great Peconic Bay (sand bottom and 6" to 4' deep) for 15 years with a 50-lb mushroom, 10-15' of chain and 15-20' of 1/2" 3-strand nylon. It never went anywhere. JimP |
Matthew
posted 06-03-2003 02:53 PM ET (US)
Dave,My family always used four 8"x8"x16" cement blocks with chain snaked through the openings and fastened to itself. We went a bit overboard running the chain all the way to the industrial size buoy. You could probably use 10' of chain and then 3 strand the rest of the way. Matt |
Capt_Tidy
posted 06-04-2003 12:02 PM ET (US)
I think we used a 283 V8 block at the cottage... been there since 1968 - no problems. The block has actually settled into the sand and all you can see is the chain/rope leader.But why moor - we stopped a long time ago and simply drive the boats onto the beach. No one would swim out! |
Bertramp
posted 06-04-2003 05:16 PM ET (US)
I wouldn't trust anything but a mushroom anchor .... the sound is a serious body of water. Engine blocks and cinder blocks may work for the lake, but if the Coasties catch you with the engine block ...yikes. The sound can be like a lake at times, but when it's ugly ... you don't want to be out in a 13 ...and you really won't want the 13 sittin' out there without a really serious mooring setup. |
JohnJ80
posted 06-04-2003 10:01 PM ET (US)
This works really well - I moored my J22 sailboat for 10 years on a set up like this and it saw many serious storms.connect 3 2 steps oversized danforth anchors on rodes coming together at a common spot. put the anchors out separated by 120 degrees and make sure that you have the 3 lines tight on the bottom. (There is little trick to this - get two on the bottom dug in, pass a line through the flukes of the third and make sure you have both ends - back this down hard, feeling the anchor flukes drag on the bottom. Let one side of the rope go when it is tight). Attach a pennat line from the attachment of the 3 anchors up to a mooring buoy. This should hold in almost anything and is pretty reasonable in cost. |
Jarhead
posted 06-05-2003 08:05 AM ET (US)
Dave..If I understand correctly it's two weeks, 13', and your going to pull it out if it gets rough. Sounds to me like the 5 gal. bucket idea would do the trick. KISS.. (K)eep (I)t (S)imple (S)tupid My 2 cents.. |
