ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Bimini Top
Author | Topic: Bimini Top |
Bob Zollo |
posted 12-06-2003 04:13 PM ET (US)
Do anyone know where I can have a Bimini Top made for the center console only ? Thnaks BZ |
BugsyG |
posted 12-07-2003 08:28 AM ET (US)
Hi Bob, Most bimini's go over the console. It all depends on how you would want it. What kind of Whaler do you have? How are the rails on it? all these factors come in to play when you are going to install a bimini. You want minimal swaying and bagginess. You want to make sure that you have that bimini screaming tight becuase Sunbrella fabric has a 2-3% expansion factor. If you make the top drum tight, and you are basically able to bounce a 10lb. weight on it, then it will slack out so that its easy to put on. Please let me know how your BW is set up so I can give you further information. I have pictures of mine if you have a Montauk. JAZZ |
Bob Zollo |
posted 12-07-2003 10:01 AM ET (US)
Thank you Jazz I will like the center console only to be covered so I can add some certains to the side and a roll up windsheild.It will be like a T Top but it will be able to fold down so I can get it in the garage,I will like to inclose the center console .Is this like yours? I have a 1998 17' Outrage with a leaning post livebait 25 gal.Trying to look forif it has a wash down .Can't tell? Thanks BZ |
BugsyG |
posted 12-07-2003 01:15 PM ET (US)
Hi Bob, What you want is an enclosure. Depends on which type of glass you want too. You could have anything from 30 gauge to Strata-Glass which is the good stuff. An enclosure wouldn't be too hard to put on that boat. I have white on my boat, I am going to put an enclosure on her over winter. I have all Thick-walled Stainless on my boat, I have no straps to secure it. Its all tubing. This way you don't get any swaying action. I anchored my top with Stainless pop-rivits and 1/4 20 Stainless bolts with locking nuts. I made them super tight but not so tight that you kink the stainless. It can be done. Where do you live? You want to make sure that you crank that top down so that it can go through a hurricane and have no problems. Thanks Bob! JAZZ |
Bob Zollo |
posted 12-07-2003 03:43 PM ET (US)
Hi Jazz I live west of Boston Mass My Boat just fits in my garage I had to take the windshield off so I will fit in . Thats way I need a bimini that will fold down and I can unzip the side curtins Can I make something like that work? BZ |
Buckda |
posted 12-07-2003 03:48 PM ET (US)
Bob - Check out www.millscanvas.com . (Mills Canvas has been the OEM canvas supplier for Whaler for a long time.) Tell them exactly what you want - they can quote you a fair price on high-quality canvas work - if you're not looking for the complete Mills Canvas system (seen on Cetecea) with the forward shelter, windshield, flying top, side curtains and aft curtain, they may be able to custom make exactly what you are looking for (i.e. a small covered area in the center of the boat.(?)) I think you will be happy with the quality of workmanship and the comfort that the Mills system provides. By the way - they have a suntop for your model on Clearance (as of December 3, 2003). Hope that helps. Dave |
BugsyG |
posted 12-07-2003 04:25 PM ET (US)
Bob, Mill's Canvas is acceptable, however, if you want a good tight custom fit, it is best that you go to a local canvas shop. JAZZ |
Buckda |
posted 12-07-2003 05:20 PM ET (US)
Bugsy - All due respect, however I have seen "quality" local canvas work literally docked side by side to a boat equipped with the full Mills system, and I stand by my advice as the best place to start a search for any canvas rigging options for any Whaler. OEM carries with it privileges and responsibilities - privileges of access to factory specifications and responsibilities to deliver quality and workmanship appropriate to the product to which it is to be applied. Why wouldn't you "think twice" about a product that was made specifically to fit your boat, but prefer to go to someone who is a generalist and makes canvas for hundreds of different boats as customer's needs dictate? It is like suggesting someone with cancer see his GP to find out what the best treatment option is - sure the GP is local, and knows you - but I'd rather go to a specialist. Bob - I'm sure you already realize this, but for repetition sake, and for the sake of new members to this site: Take all advice given with a grain of salt - consider the source - read past posts from people before you make an expensive decision based on advice of strangers. (That goes for posts/advice from me too!). I suggest speaking with Mills - either for a solution from them, or for suggestions for local shops in your area that can help you with a system you are looking for. I also respectfully suggest that you contact persons on this site who may respond moving forward (or have posted responses to similar topics in the past) about their experiences with Mills Canvas and other canvas makers, respectively. A general observation: Mills is a bit pricey, however most people who own and use the system on their boats are extremely happy. In my opinion, if Mills has a pattern for your boat, you can't do any better in terms of quality and longevity (with proper care). http://continuouswave.com/ubb/Forum6/HTML/000029.html Hope these links help - use the search function at the top of the page to conduct site searches. It takes some digging sometimes, but you can find so much information on this site, it can make your eyes water. Best of luck in your search. Dave |
Buckda |
posted 12-07-2003 05:31 PM ET (US)
In an effort to defuse things before they are taken the wrong way: Bugsy - re-reading my post, I may not have used the same tact that I would have had we been speaking instead of typing - I simply disagree with your assessment that "Personally, I wouldn't think twice about Mill's Canvas, Although it will get you by until you would like to go to a local canvas shop." To me, it sounded like you were suggesting that purchasing a Mills product amounted to a temporary measure, to which I would emphatically respond: "Rubbish! Mills makes a fine, quality product that will likely be sold with the boat when it comes time to buy a new Whaler. I could not disagree with your sentiments about their product more, sir." Dave |
BugsyG |
posted 12-07-2003 07:02 PM ET (US)
Buckda, Thank you for your information. No need for any sort of confrentation. People have their opinions :-) I just offered a custom canvas job because there are pro's and con's to both. Mill's Pro: 2.) Equal or cheaper to have Mills do it. Mill's Con: 2.) Possibility of bad glass (eisenglass) or bagginess becuase of not the correct fit to the canvas ------ JAZZ |
spotsnspecks |
posted 12-07-2003 07:47 PM ET (US)
Hi Bob, I had a 17 Outrage I with a regular size bimini top. It sounds like you want something a little shorter than what most canvas shops would consider the standard size (a canvas pilothouse?). If it were me with this choice to make, I would go with a custom job from a local shop. Not because Mills or anyone else would be cheaper or of inferior quality (I doubt Mills would be either). I would be concerned with getting EXACTLY what you want. It may be difficult to communicate this via email or phone and any adjustments could be made with without shipping and more communication (confusion). You could leave the boat if need be, show them exactly wher you want snaps/zippers etc.. and they could make sure it fit snugly on your boat. They would put the buttons/snaps on your boat for you too! I would certainly call Mills as I know the the high quality they are famous for. Maybe they have done this exact pattern you desire. However, you are talking a thousand dollars or so in materials and labor for a setup like yours. For my money I would be willing to leave the boat at the local shop (check their references first) and make sure it is done right. |
SpeedBump |
posted 12-08-2003 02:45 PM ET (US)
I stand by Mills quality. I have a very old mooring cover on my 13. Made by Mills, I have used it for close to 10 years and it has held up unbelieveably well. I Ordered a consol cover for my Nauset this fall. It fit very well but I felt it was too tight across the back of the fixed pilot seat and sent it back with a suggested measurment and it was returned in two weeks sized to a tee, their service is beyond reproach. I just placed an order for a sun top w' boot cover and stainless frame that I saw in the overstocks section and saved over $300 off of their regular season cost. I feel confident the top will be equally well made as my other Mills products. Bob it sounds like you need one of their Fly tops for your boat. It is shorter than the sun top and can accept side curtains if need be. good luck |
kingfish |
posted 12-08-2003 03:35 PM ET (US)
I think we're dealing a litle with semantics here - Mills *is* custom canvas. Each piece was custom-designed for the specific model of boat they sell it to you for. The only part of the equation that can vary is the installation; if Mills' instructions are carefully followed by someone who is moderately used to working with hand tools, the installation will be better and tighter than if not. There may be a few custom shops around the country that are as good as Mills at what they do, but I seriously doubt there are any that are appreciably better. And I can state unequivocally that there is *no* shop that has the history and experience with Boston Whalers that Mills does. kingfish |
Bob Zollo |
posted 12-08-2003 07:37 PM ET (US)
can you give me Wm. Miller & Co e mail address? I'm trying to get a photo of a canvas pilothouse or Fly top that will fit on my center console. Thank for all the info !!BZ |
diamondjj |
posted 12-08-2003 07:46 PM ET (US)
www.millscanvas.com |
diamondjj |
posted 12-08-2003 07:47 PM ET (US)
Sorry, wrong company. I need to put my glasses on.... |
kingfish |
posted 12-08-2003 08:18 PM ET (US)
Bob- The tops we're describing here do not fit "on" your center console; they attach to the gunwales of your boat, on either side of your center console. They fold up and depending upon the make and model, may slide forward once folded to be out of the way. The Mills flytop is shorter from front to back when flying than the suntop, which is more like what most people refer to as a bimini top. The flytop if one is available for your model of Whaler, has zippers and fasteners so a windshield (and forward shelter), side curtains and rear curtain , all custom fitted to your boat, can be attached. If what you want is something that attaches to your console, then you are looking for a "T-top", not a bimini. That is a different thing altogether with a much more rigid and substantial frame than a bimini. Here is Wm. J. Mills website (diamondjj, I think this *is* what he was looking for, even though he did not exactly say it). |
Buckda |
posted 12-09-2003 08:21 AM ET (US)
Or call Christy in the Boston Whaler department: 1.800.477.1535 Dave |
Bob Zollo |
posted 12-09-2003 06:24 PM ET (US)
Any Photo's of a center console canvas pilothouse or a fly top with windshield Thanks BZ |
Bob Zollo |
posted 12-09-2003 06:27 PM ET (US)
