posted 02-10-2004 08:31 PM ET (US)
Since I just repowered, here's a few numbers for you:* remove old engine, 1.0 hr
* clean up controls & transom, 1.0 hr
* mount new motor, 3.0 hr (fwiw, that seems a bit high to me)
* install smartcraft, 1.25 hr
* install new control box & wiring harness, 2.75 hrs
* run ddt checkout, .75 hr
Obviously, what this means in $ depends on your local hourly rate--in Portland, OR, that worked out to be $65/hr.
Although I stayed with a Mercury outboard, I wanted a new control box, control cables, wiring harness and keyswitch--all the old components (except control cables) were original with the boat, and I think (in this case) it would have been false economy to not replace them. This upped the price by a few hundred $ more than it had to be, but cie la vie. Also, all rigging was properly routed thru the rigging tunnel (old control cables were routed along the gunnel)
