  Capacity plate
Author Topic:   Capacity plate
dlmilkey posted 10-28-2005 08:34 PM ET (US)   Profile for dlmilkey   Send Email to dlmilkey
Anyone ever attempted to reproduce the capacity plate on thier Whaler? My '85 GTX could use a new plate, as it is really worn.
fadams posted 10-28-2005 10:43 PM ET (US)     Profile for fadams  Send Email to fadams
The capacity plate on my 1984 outrage 18 incorrectly read 70 hp as maximum. Apparently it was sent from the factory without the center console on yet and was being rated for a tiller type engine. I bought it in 1995 and after some letter writing between dealer and manufacturer they sent me a new correct plate listing 150 hp maximum that they had sitting around the factory. Good luck.
Frank
winbone posted 10-28-2005 11:06 PM ET (US)     Profile for winbone
Go to the reference section on the continuous whaler site. Look at the article about restoring a a 13' whaler. Props once again to the contributors on this site.
dlmilkey posted 10-29-2005 06:53 AM ET (US)     Profile for dlmilkey  Send Email to dlmilkey
Thanks to you both for the advice. (Waking up this am, I realized I probaly should have posted this question on the repairs section...)
That 13' plate came out perfect, giving me the inspiration to spend the winter poking around with duplicating mine. If your going to restore the best boat, you might as well do it right!
Jonathan posted 11-03-2005 08:53 AM ET (US)     Profile for Jonathan  Send Email to Jonathan
I made a plate for my 13ftr. I had the artwork made based on drawings provided by Chuck Bennett from BW. A bit of work involved to make a one-off but it really does make a great finishing touch.
http://photobucket.com/albums/v402/jtsun/Boston%20Whaler/?action=view¤t=cp002.jpg
banff22 posted 11-03-2005 09:13 AM ET (US)     Profile for banff22  Send Email to banff22
I think this is what you are looking for.
http://whalercentral.com/downloads.php?cat_id=4
If the link does not work then you will have to become a member of Whaler Central and look under the heading "downloads". There are capicyt plates for a few different models.
Peter
jeffs22outrage posted 11-03-2005 09:13 AM ET (US)     Profile for jeffs22outrage  Send Email to jeffs22outrage
I recreated a number of capacity plates that can be downloaded on whalercentral. Your GTX uses the same as an 18 outrage I am guessing.
Here is the image
http://whalercentral.com/photogallery.php?photo=362
Here is were it can be downloaded from
I remade a capacity plate for myself and one for Shelia as well. Start out by drilling out the existing rivets in the corners of the cap plate. Once off I used the back side of the plate to mount the new graphic to. First I started with a layer of white vinyl. Then I printed out my file on an adhesvise clear vinyl and laided that over white. Then laid a UV protectant clear vinyl over it all to seal it all up. I used an exacto to trim up the edges and cut out the holes in the corners. I add a little sealent into the holes where the plate attaches to the hull and then use Stainless screws to reattach the plate.
whalerdude posted 11-03-2005 09:26 AM ET (US)     Profile for whalerdude  Send Email to whalerdude
I had an excellent duplicate plate made for my 22 Outrage.
I took off the riveted on old damaged cert. plate and had a local company called 'Signs Now' (847 249-7445) make a copy of it and duplicate it on to a metal foil decal.
They had to re-enter the letters that were worn off.
It came out great and was a nice finishing touch to my restoration project.
It only cost me about $20 as well.
Sheila posted 11-03-2005 03:19 PM ET (US)     Profile for Sheila  Send Email to Sheila
I can attest to the quality of Jeff's reproductions. Thanks again, Jeff! And thanks to Tom, who shot a photo of the plate from his Revenge, as mine was illegible.
simonmeridew posted 11-29-2005 07:22 PM ET (US)     Profile for simonmeridew  Send Email to simonmeridew
I need a new capacity plate for my 84 Montauk. I can see two ways of doing it, based on Jeff's post and whalerdude's post.
I downloaded the excellent pic of the 17'plate thanks to Jeff, I resized it with Adobe Photoshop Elements to 4" X 4" and printed it out on a glossy paper. Super graphics!!!
A couple of questions Jeff: your directions talk about printing it out on a sheet of clear adhesive vinyl, did you just use your regular inkjet computer printer to print it out?
Where did you get the layers of vinyl, specifically the adhesive one and especially the UV protectant clear layer??
Whlerdude: did the "Signs Now" company start with a photo of a good plate or did they make up the graphics themselves? Do you think they're digitally capable so that sending them a CD pic would set them up with what they need? Realize you can't speak for them yourself but just trying to get guidance to get off ground zero.
Thanks for help with a winter project.
simonmeridew
jandrewg posted 05-26-2007 01:30 PM ET (US)     Profile for jandrewg  Send Email to jandrewg
Thanks to all for the information, especially jeffs22outrage as I downloaded the ZIP and got the very helpful JPG and PDF files inside.
I've been in the graphics business for too many years to actually say (have had CAD since the mid '80s, and had hand cut vinyl since the '70s). Most of what I do is fleet markings (Sheriff and Police graphics, local Fire Departments, small fleet markings for heating/plumbing contractors, etc.). What I'll do with these files is print them on clear 2 mil cast vinyl with a solvent ink jet commercial printer, and laminate another clear 2 mil on top, finally profile cutting it to perfect fit my original aluminum plate. The solvent ink has an outdoor rating but will wear off after a couple of years or more, so the protective top layer will alleviate this problem and give a product that will last indefinately (2 mil cast vinyl has a rating of 7-9 years, subject to UV exposure. In real life with a little caution and care it will hold up at least twice that long in my experience).
I'd offer to help anyone out there with the same process, but I don't have an immediate source for the aluminum blanks (with the radiused corners and holes punched), so the mechanics of having the old ones shipped and redone might be more problem that it is worth. The material in the machine prints on 54" wide material, so obviously we could stack a bunch of them on one run. Because of this, I'll print several extra for my Montauk, anybody out there need one for same?
Thanks again for the help.
John Green
