| Author | Topic: Fast displacement hulls of the future? |
| cooper1958nc |
With fuel and carbon concerns increasing, powering boats as efficiently as possible is always an interesting topic. Recently I operated a pontoon boat and was pretty surprised at the speed this 22' boat would make on 50hp. Even loaded to the gills with 10 people or so, cruise speed on the 50 resulted in 12-13 mph. This is way beyond hull speed yet there was no bow rise and the pontoon hull is not designed to lift. Sailing cats also seem to sail way above hull speed, yet it is hard to say they are planing in any realistic sense. There is not much literature on this, but I would not be surprise to see major manufacturers going to fast displacement cats if they can be driven a moderate to low speeds with very little power. |
| 20dauntless |
Glacier Bay Cats are all displacement hulls...you should be able to find more information on them by searching google or checking their site. Unlike displacement monohulls which are limited to 1.34 x the square root of waterline length, displacement cats can achieve much higher speeds. |
| boatdryver |
I tested a Glacier Bay 26 four years ago on choppy San Francisco Bay with a sales rep. I was very very impressed with the ride. But then the rep spied a container ship entering the Harbor at 10 knots and decided to cross the ship's wake at 22 knots. Well, the wake was much higher than bargained for and my buddy did a face plant on the deck-he looked like a road kill. The thing that turned me off, though, other than the sticker shock, was the fuel flow meter which showed 17 gallons per hour at about 22 knots. So even though displacement cats can exceed traditional (1.34xsquare root of waterline length) hull speed it appears they require a lot of energy to do so. Does anyone have personal experience with one of these? JimL |
| pglein |
Sailing catamarans are not displacement hulls. They don't have to hop up on top of the water like a flat-bottom or deep-vee to be considered "planing". If they're producing lift, they're planing. |
| TransAm |
Won't happen. Consumers will flat out reject it. Technology will overtake any need for such a thing. |
| cooper1958nc |
"Sailing catamarans are not displacement hulls. They don't have to hop up on top of the water like a flat-bottom or deep-vee to be considered "planing". If they're producing lift, they're planing." How do you know if they are producing lift? Round-pontoon boats will not produce much if any lift, and they run flat at like zero angle of attack. But they go far beyond hull speed on small amounts of power. "Won't happen. Consumers will flat out reject it. Technology will overtake any need for such a thing." Well, this is a type of technology, and further, technology can't change physical fundamentals. |
| pglein |
Lets first define the terms we're using.
quote: All displacement hulls are probably really semi-displacement. That is, if you put enough power on them, at some point, the lift of the forward half will overcome the downforce suction of the aft portion and they will start to squat and just barely "plane". But with hulls generally classified as displacement, the amount of force required to do this is absurd and the hull will generally become unstable. All planing hulls are displcement hulls when they're going slow. Sailing catamarans glide through the water at displacement speeds most of the time. But when they catch a good gust of wind, they usually start producing a moderate amount of lift. NOT ALL SAILBOATS ARE DISPLACEMENT hulls. Most of the small, competitive daysailer classes are actually planing hulls. Note that "hull speed" is generally misunderstood. The general formulas out there assume a traditional displacement shape. Many unconventional boats (like catamarans) have unconventional hull shapes that are able to achieve far in excess of their supposed "hull speed" while still technically not producing significant lift. Kayaks are, perhaps, the best example of this. Their hulls would probably be best classified as displacement. Yet, their extremely small size, narrow beam, and sharp entry and exit angles allow them to travel at more than twice what one might predict their hull speed to be. There are no absolutes in hull design. |
| Chuck Tribolet |
"There are no absolutes in hull design." That's one of the most sensible things I've heard in a while.
| tmann45 |
"There are no absolutes in hull design." Absolutely! The "faster than hull speed" is made possible by the large length to beam ratio (slenderness) of the hull. |
| elaelap |
Different strokes: http://i22.photobucket.com/albums/b309/elaelap/Hydrofoilspeedster.jpg http://i22.photobucket.com/albums/b309/elaelap/LukaMikeKauaiwedding025. jpg |
| tmann45 |
Got any idea how fast the hydrofoil trimaran is going? |
| TransAm |
Sorry, I dont see myself relaxing, having a cold beer on one of those rigs. If that is part of your work-out routine, or something you do once in a while, fine. But I usually get on the water to relax, not bust my hump just to stay on the boat. |
| Hoosier |
OK, how would you classify this one? This is an adaptaion of a commercial high speed ferry design. I can almost see the hull lines of my classic Montauk in it. |
| Pierce |
Displacement hull. Very fast displacement hull though! |
| John W |
One type of hull design that has caught my attention are the "Seabright tunnel hull" boats designed by William & John Atkin (http://www.atkinboatplans.com/). They reach speeds of up to 20 mph or so with very little power. An example is "Rescue Minor", a 20 foot inboard skiff that goes 20 mph on 18 hp, runs in 6" of water, and gets 28 miles per gallon! An article on the design, written by Robb White, was featured in WoodenBoat magazine in March 2006...there is also an article about the boat, with pictures, on Robb White's website here: Here is the link to Atkins' plan for Rescue Minor, along with a link to pictures of the boat: http://www.boat-links.com/Atkinco/Utilities/RescueMinor.html Atkin designed various of these "Seabright tunnel hull powerboats" up to around 40 feet in length. They all were very fuel efficient and shallow draft...but they are not as fast as modern, power-hungry planing boats....the tunnel hull starts to push the bow down over a certain speed. As planing boats go, the classic 16' and 21' Whalers are more fuel efficient than most, but Rescue Minor takes it to a much higher level of fuel efficiency. John |
| Hoosier |
How about this one? |
| tomol |
Tony, great shot of that trimaran. I think the speed record for one of those big hydrofoils is something like 42 knots. As an aside I just got word that the magical 50 knot barrier was just broken by a kite surfer. But back to the catamaran lift/displacement discussion. When I used to race Hobie Cats in the 70's the rule of thumb was to keep crew weight forward to get the flat transoms out of the water at slow speeds when the hull behaved like a displacement hull. |
